C++ compile errors for qtopia application
Posted: Wed Sep 02, 2009 8:11 am
by peterlin55118
:roll:
I am trying to compile a C++ Metronome program for Qtopia,
seems CMAKE made is OK, but MAKE had 2 errors, Would be
very grateful if you can give me some hints on why, I would
see them as my system setup issues.
Thanks in advance!
Peter
Below are the CMAKE and MAKE screen shot.
[root@localhost Maestro_Metronome_1.2]# cmake /home/Maestro_Metronome_1.2/
-- The C compiler identification is GNU
-- The CXX compiler identification is GNU
-- Check for working C compiler: /usr/lib/ccache/gcc
-- Check for working C compiler: /usr/lib/ccache/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/lib/ccache/c++
-- Check for working CXX compiler: /usr/lib/ccache/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Looking for Q_WS_X11
-- Looking for Q_WS_X11 - found
-- Looking for Q_WS_WIN
-- Looking for Q_WS_WIN - not found.
-- Looking for Q_WS_QWS
-- Looking for Q_WS_QWS - not found.
-- Looking for Q_WS_MAC
-- Looking for Q_WS_MAC - not found.
-- Found Qt-Version 4.3.4
-- Found OpenSSL: /usr/lib/libssl.so
-- Looking for _POSIX_TIMERS
-- Looking for _POSIX_TIMERS - found
-- Configuring done
-- Generating done
-- Build files have been written to: /home/Maestro_Metronome_1.2
[root@localhost Maestro_Metronome_1.2]# make
[ 3%] Building CXX object CMakeFiles/maestro-metronome.dir/src/window.o
In file included from /home/Maestro_Metronome_1.2/src/window.h:30,
from /home/Maestro_Metronome_1.2/src/window.cpp:24:
/home/Maestro_Metronome_1.2/src/soundplayer.h:32:32: error: phonon/mediaobject.h: No such file or directory
/home/Maestro_Metronome_1.2/src/soundplayer.h:33:25: error: phonon/path.h: No such file or directory
/home/Maestro_Metronome_1.2/src/soundplayer.h:34:32: error: phonon/audiooutput.h: No such file or directory
/home/Maestro_Metronome_1.2/src/soundplayer.h:59: error: ‘Phonon’ has not been declared
/home/Maestro_Metronome_1.2/src/soundplayer.h:59: error: ISO C++ forbids declaration of ‘MediaObject’ with no type
/home/Maestro_Metronome_1.2/src/soundplayer.h:59: error: expected ‘;’ before ‘*’ token
/home/Maestro_Metronome_1.2/src/soundplayer.h:60: error: ‘Phonon’ has not been declared
/home/Maestro_Metronome_1.2/src/soundplayer.h:60: error: ISO C++ forbids declaration of ‘MediaObject’ with no type
/home/Maestro_Metronome_1.2/src/soundplayer.h:60: error: expected ‘;’ before ‘*’ token
In file included from /home/Maestro_Metronome_1.2/src/window.cpp:24:
/home/Maestro_Metronome_1.2/src/window.h:36: error: expected constructor, destructor, or type conversion before ‘class’
/home/Maestro_Metronome_1.2/src/window.h:41: error: expected constructor, destructor, or type conversion before ‘class’
make[2]: *** [CMakeFiles/maestro-metronome.dir/src/window.o] Error 1
make[1]: *** [CMakeFiles/maestro-metronome.dir/all] Error 2
make: *** [all] Error 2
