Using ADC channels
kdalyan
Using ADC channels
Post by kdalyan » Fri Sep 11, 2009 1:42 am
How can use the ADC channels on GPIO socket. i want to use 3 adc input but the board has only one pot. i can connect 2 extra but in software how can use them. is ADC drive in linux adaptable for changing the channels?
is there a simple example please?
Thankyou for your help
Re: Using ADC channels
Post by nicolas » Fri Sep 11, 2009 4:45 pm
Im not sure if linux has a driver for it.
But directly via i/o...
To read the other channels you need to change the channel on the mux then tell the adc to perform a conversion then read the value (unless you have the READ_START bit set, in which case a read will cause an auto adc calculation)
To change the channel, set the proper bits of the ADCCON register.
See sample code without OS\2440test\src\adc.c for example
Sak1s
Post by Sak1s » Mon May 17, 2010 11:08 am
hello.I there any tip about adding an adc input ?
