White Screen Novice needing assist
marke
Post by marke » Mon May 17, 2010 7:52 am
Hi all,
I have successfully got the mini2440 running from NOR, but when I try to boot from NAND all I get is a very white screen, there is nothing from the console. I am assuming the board is not booting up any advise is welcome.
Board is a 256mb model with T35 lcd if this helps!
thanks in advance.
Abuda
Re: White Screen Novice needing assist
Post by Abuda » Wed Jun 09, 2010 4:48 pm
I have the same problem.
Linux and WINCE6 work in 256mb board but WINCE5 run just first time when the switch is in the NOR position.
I have 128mb and 1Gb boards and these boards don't have this problem with wince5.
Post by esky-sh » Thu Jun 17, 2010 6:34 pm
you can use 'x', 'v' and 'w' command for wince installation on nand flash.
