Application auto launch
How can an application automatically launch upon power on?
Re: Application auto launch
Put a shortcut in the Startup folder. (Like in desktop variants of windows)
Or
Make use of the [HKEY_LOCAL_MACHINE\init] registry key
Or
Thanks. One of the problems I'm having is that my app is running out of folder /Program Files. The contents do not persist on power off and on for this S3C2440 board. Any solution?
That is because the filesystem is non-persisting. There is a way to have WinCE write back the changes to the flash storage image - but I have not been able to figure it out. (This would actually be setup when creating the WinCE image itself).
Two options:
A) Use an SD card
B) Use the persistent storage "drive" on the unit. It is at the root, called ResidentFlash
Two options:
A) Use an SD card
Users browsing this forum: No registered users and 13 guests
