2440 deleting files at every turn off
Anyone knows why that is? Any file I create or drivers I install, go away when I reset it or turn it off.....
Re: 2440 deleting files at every turn off
Can you be more specific. What OS ?
CE 5.0, compiled from the project file provided, or with the image provided on the DVD with the board. It doesn't forget the time tho.....
The image as provided is a RAM based filesystem.
It does not preserve the file changes across boots, but it does preserve hive changes.
The Time is preserved because it makes use of the RTC on the Mini2440 board.
There is a configuration that will allow you to make the filesystem persistent but I dont know exactly.
It may be the so called "ROM Based Filesystem"
I rebuilt the image with ROM based FS only but same thing.....
It's gotta be wither a vivi or a PB5 setting. I'll keep playing with it
Was the process you followed like this viewtopic.php?f=15&t=178 ?
Users browsing this forum: No registered users and 9 guests
