how i do for writing a char with userkey button in bsp?
Hello, i would like to cancel all up, down, right.... buttons for when i push it, it write a charactere :
exemple : i press k1, it write : A
i press k2 button, it write : B
in wordpad.
i think it is in userkey.cpp but i don't know how modify for to doo that.
by
valentin
in wordpad.
by
valentin
Re: how i do for writing a char with userkey button in bsp?
I havent tried it, but from the code, I think commenting out the code inside of
and
should do the trick.
DWORD KEY_Init(DWORD dwContext)
BOOL KEY_Deinit(DWORD hDeviceContext)
can i have a exemple ?
by
valentin
by
valentin
An example of the image, the code, or ?
for the code, what i must modify.
by
valentin
by
valentin
Like I said in the previous original reply. Comment out the functions I noted and give it a try.
Im sorry but i dont have the time to recompile a specific version for you to try. I can only give you the information to then follow up on and try it yourself.
The commenting out of the two functions code should remove the interrupt registration and also deinitialization.
By doing so, pressing the buttons wont cause an interrupt and thus you are free to control the buttons from elsewhere.
hello,
whell, first,
what file i must modify for make a new windows ce image?
second, what i must modify for to do what i want?
by
valentin
whell, first,
by
valentin
Users browsing this forum: No registered users and 18 guests
