I am trying to use PanelLink to display image onto the panel. I have tried and compiled the repo
https://github.com/NXElec/panelLink but I cannot figure out what is wrong? There is nothing displayed on the panel. Am I doing something wrong with the program parameters?
I have also read the document https://www.nxelec.com/documents/bp/Pan ... _Rev03.pdf
I know the panel is working in AIDA. However I would like to develop custom software if possible.
Appreciate any help. Thank you.
PanelLink sample usage?
Re: PanelLink sample usage?
The code on github is little obsolete.
pipeid->PipeOutId should be assigned to 1(first bulk out endpoint address) before function QueryDeviceEndpoints() return.
Here is an example
We will update github soon to reflect latest firmware.
BOOL QueryDeviceEndpoints(WINUSB_INTERFACE_HANDLE hDeviceHandle, PIPE_ID* pipeid)
if (hDeviceHandle == INVALID_HANDLE_VALUE)
return FALSE;
BOOL bResult = TRUE;
USB_INTERFACE_DESCRIPTOR InterfaceDescriptor;
ZeroMemory(&InterfaceDescriptor, sizeof(USB_INTERFACE_DESCRIPTOR));
WINUSB_PIPE_INFORMATION Pipe;
ZeroMemory(&Pipe, sizeof(WINUSB_PIPE_INFORMATION));
bResult = WinUsb_QueryInterfaceSettings(hDeviceHandle, 0, &InterfaceDescriptor);
if (bResult)
for (int index = 0; index < InterfaceDescriptor.bNumEndpoints; index++)
bResult = WinUsb_QueryPipe(hDeviceHandle, 0, index, &Pipe);
if (bResult)
if (Pipe.PipeType == UsbdPipeTypeControl)
printf("Endpoint index: %d Pipe type: %d Control Pipe ID: %d.\n", index, Pipe.PipeType, Pipe.PipeId);
if (Pipe.PipeType == UsbdPipeTypeIsochronous)
printf("Endpoint index: %d Pipe type: %d Isochronous Pipe ID: %d.\n", index, Pipe.PipeType, Pipe.PipeId);
if (Pipe.PipeType == UsbdPipeTypeBulk)
if (USB_ENDPOINT_DIRECTION_IN(Pipe.PipeId))
printf("Endpoint index: %d Pipe type: %d Bulk In Pipe ID: %x.\n", index, Pipe.PipeType, Pipe.PipeId);
pipeid->PipeInId = Pipe.PipeId;
if (USB_ENDPOINT_DIRECTION_OUT(Pipe.PipeId))
printf("Endpoint index: %d Pipe type: %d Bulk Out Pipe ID: %x.\n", index, Pipe.PipeType, Pipe.PipeId);
pipeid->PipeOutId = Pipe.PipeId;
if (Pipe.PipeType == UsbdPipeTypeInterrupt)
printf("Endpoint index: %d Pipe type: %d Interrupt Pipe ID: %d.\n", index, Pipe.PipeType, Pipe.PipeId);
else
continue;
done:
return bResult;
Here is an example
return FALSE;
if (bResult)
for (int index = 0; index < 2; index++)
That fixed it. Thanks!
Users browsing this forum: No registered users and 18 guests
