Page 3 of 3
Re: Partition Issue
Posted: Tue Feb 27, 2024 11:51 pm
by Myrr
ok that is done - there is now a solid light on the unit
Re: Partition Issue
Posted: Wed Feb 28, 2024 12:10 am
by Myrr
I must retire for today - not sure the next step, the drivers are installed, the unit and the PC have been restarted, however there's no device detected in windows (in this mode).
The files were copied over to the FAT16 directory using DG. I did have to format that partition first with DG as it was generating an error when copying the files over in DG.
I formatted the FAT32 directory using DG.
Thank you again
Re: Partition Issue
Posted: Wed Feb 28, 2024 5:29 pm
Looking good except FAT16 files. You can refer to BeadaPanel_Rev_7.01_Compatibilities_Matrix.pdf on onedrive for FAT16 files choosing.
Re: Partition Issue
Posted: Wed Feb 28, 2024 5:52 pm
by Myrr
Excellent. Now have basic functionality once again!
Can I simply create a .txt .ini file now with the correct paremeters for a "O" backlight on standby?
And thank you again.
Re: Partition Issue
Posted: Wed Feb 28, 2024 6:09 pm
https://1drv.ms/f/s!ArGfiTxjUGUl_znxPZ1 ... N?e=bg7Prz
you can drag the folders on onedrive to your FAT32 partition.
Re: Partition Issue
Posted: Wed Feb 28, 2024 6:28 pm
by Myrr
Ok it does appear to be working. This is a relief! Thank you for the support.
Will monitor from here on out hopefully it behaves as it should!
