I am using a DC/DC converter to power my board on my vehicle, but I need to aquire a new AC/DC converter to run the board.
The AC/DC converter shipped with my board had a bad connector wire and so I never used it. It says 12V-2.5A which would be ~25W, I assume thats much higher than necessary or even allowed.
I would like to go as small as possible on the AMPs, and avoid putting too much through the board
(I am running USB Hub w/USB Bluetooth, WIFI, the RS232 port and SDCard) what is the appropriate MAX amperage to allow
to run through the board?
Thank you,
Todd
QQ2440V3 12 volt power - min/max amps required and FUSES.
Re: QQ2440V3 12 volt power - min/max amps required and FUSES.
This should be simple, wire up your multimeter to measure the current of your current setup.
See how much it needs, then youll know 100%.
