Latest USB Drivers for DNW tool
This new driver has some improvement for blue screen issue.
- usb_driver.rar
- (10.02 KiB) Downloaded 2418 times
Re: Latest USB Drivers for DNW tool
Thanks a bunch!
The earlier version seemed to work just fine for me with WinXP, but not on the same WinXP through Virtualbox (bluescreen when installing). Very odd. But as said, this one works!
Has anyone got the usb driver and dnwto work with win2k?
win2k device manager reports usb device drivers not installed for supplied dvd and for latest downloads from ftp site.
I upgraded from Windows to ubuntu on another PC . Is there a dnw equivalent for linux?
I'd like to avoid windows OS's as much as possible.
Hello, I'm using Windows 7 build 7000 x64 and DNW is not able to use/detect USB port. I can't install the USB drivers. They're not recognized by Windows. In the device management I can see "SEC S3C2410X test B/D" driver not installed. Does anybody has a solution ? Who is providing these drivers ? Are they open source ? Thanks.
Yea I'm having this same issue I cant get it to work in windows 7, can't install drivers and it shows up in device manager
Well I did it !! All you need to do is to install "Windows XP Mode" in Windows 7 x64. It is an XP virtual machine and you'll be able to make DNW tool run correctly. You can find "Windows XP Mode" in Microsoft website.
There are 2 files to install : Virtual PC and a special Windows XP image. When your virtual machine is running, install the drivers you need. Then, run DNW tool in XP mode (right click on the program icon and select XP mode). That's all folks !
- Contact:
Latest USB Drivers
Is it possible to post so that only a certain member or members can read it? On another foum we use secret=Name and /secret to make this happen.
Is there a way to make something like this happen?
Users browsing this forum: No registered users and 8 guests
