xorg on mini2440
imenu
xorg on mini2440
Post by imenu » Thu Mar 11, 2010 7:46 am
Hello guys, how are you all? I hope everything ok... I was looking for a manner to run xorg inside a mini2440(with TFT touch 8'') emdebian distro.
I was aiming to run icevm inside xorg but i couldn´t make it... does anyone has any directions or documentation that can help me in this situation? I can install the last kernel, build the root fs , uboot, and even compile uImage sucessfully without kernel panic. (Not with the zImage_A80, because this image available on friendlyarm.net does not work for me at all).
When boot my system into runlevel 2, I proceed to the xorg installation using debian´s aptitude and after this my TFT touchscreen stays blank (white) and blinking somtimes... I can´t calibrate the driver for touchscreen, and even when I run X ou startx (no errors in console) the touch still stays blank and blinking.
I think I maybe making something wrong when compiling zImage or even on xorg config..but i can identify the error source...
For that reason i´m looking for some tutorial which I can see all steps for making x works.. if someone can help me, i would be very greatful.
Thanks in advance;
My best regards,
Carlos
imenu
Re: xorg on mini2440
Post by imenu » Sun Mar 21, 2010 10:34 am
Anyone?
Delavar
Post by Delavar » Sun Mar 21, 2010 10:21 pm
Try driver "fbdev" in xorg config file. But you can't do much with xorg. With debian it leaves only 2 MB free memory. And it's so slow...
imenu
Post by imenu » Mon Mar 22, 2010 7:52 am
that´s bad... Do you recommend other way to get this arm work in graph mode?
Users browsing this forum: No registered users and 8 guests
