Does someone know where to buy the little adapter card between the Hirose LCD connector located on the mini2440 mother board and the Flat Flexible Cable (FFC) ?
Due to a electrical contact problem, mine is out of order and I don't have the necessary soldering material to repair it (I have tried with a classical soldering iron and my card is now no longer usable...).
Is there an other solution to make a direct link between the Hirose DF9-41S-1V connector on the mini2440 and the FFC connector located on the LCD ?
Thanks in advance
adapter card to connect LCD
Re: adapter card to connect LCD
you can contact the seller, they may have a solution.
Users browsing this forum: No registered users and 15 guests
