Kernel reboots while unpacking
Posted: Sun Jun 20, 2010 2:09 pm
I have QQ2440 board and I have a problem with booting my board since yesterday. The kernel reboots in the middle of uncompressing itself and I can't find any reason for that. I haven't been using the board for a couple weeks but I left it in perfectly working state with Angstrom distro running on the SD card.
My setup is:
I am 100% sure that the "S3C Reboot on decompression errror" is switched off in the Kernel config.
Here's the output I get on the serial terminal:
I'm currently recompiling the kernel with some extra debug options on to see if there will be any hints on what goes wrong but if anyone had same issue and has a clue how to solve it I would really appriciate his help.
Thanks & regards,
Chris Ciesielski
My setup is:
- U-Boot 1.3.2-moko12
Linux 2.6.29 (both patched using the patches from Leshaks site)
qq2440 # printenv
bootdelay=3
baudrate=115200
ethaddr=08:00:3e:26:0a:5b
mtdids=nand0=nandflash0
mtdparts=mtdparts=nandflash0:2m@0(kernel),8m(jffs2),-(yaffs)
"noinitrd=root=/dev/mtdblock1 rootfstype=jffs2 rw console=ttySAC0,115200"
partition=nand0,0
mtddevnum=0
mtddevname=kernel
bootcmd=nand read 0x32000000 0x100000 0x200000; bootm 0x32000000
filesize=200000
fileaddr=32000000
netmask=255.255.255.0
ipaddr=192.168.0.2
serverip=192.168.0.1
bootargs=noinitrd root=/dev/mmcblk0p1 rootdelay=10 rootfstype=ext2 rw init=/sbin/init console=ttySAC0,115200
stdin=serial
stdout=serial
stderr=serial
Environment size: 572/65532 bytes
qq2440 # boot
NAND read: device 0 offset 0x100000, size 0x200000
2097152 bytes read: OK
## Booting kernel from Legacy Image at 32000000 ...
Image Name:
Created: 2009-02-13 13:30:46 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 1598560 Bytes = 1.5 MB
Load Address: 30008000
Entry Point: 30008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux.......
U-Boot 1.3.2-moko12 (Apr 18 2010 - 21:33:57)
I2C: ready
DRAM: 64 MB
Flash: 2 MB
NAND: 64 MiB
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 0
Thanks & regards,
Chris Ciesielski
