After installing supervivi-64M (using jtag) i had following problem.
Windows XP found new HW but does not recognized S3c2440 board.
DNW does not confirm USB OK.Serial communication working OK.
I have Installed USB driver correctly.
As i found that for QQ2440 board D+ pin of USB device will be pulled to high when a device connect to PC.
I already made that change on my HW.Still device is not identified as s3c2440 board and not able to transfer any images via USB.
Until now i knew that Difference between QQ2440 and Mini2440 are
MINI2440:
1. Ethernet Chip DM9000
2. User Button Number 6
3. CMOS Camera i/f add signal of I2C and EINT20
4. Power Supply Voltage 5V
5. NAND : 64M/128m/256m/1GB
6. Dimension 100 x 100 mm
7. USB_en :GPC5, so supervivi can't be used on QQ2440
QQ2440:
1. Ethernet Chip CS8900
2. User Button Number 4
3. CMOS Camera i/f no signal of I2C and EINT20
4. Power Supply Voltage 12V
5. NAND : 64M
6. Dimension 120 x 100 mm
7. USB_en: GPG12.
i do not know which changes has to be made in bootloader software side as USB_en pin is used differently on these two boards.Do we have source code for the bootloader.
please assist me,
regards,
Nirav.
DNW does not confirm USB OK on qq2440V3 board
Users browsing this forum: No registered users and 7 guests
