Nor flash EN29LV160AB programing in h-jtag?
giovaniluigi
Re: Nor flash EN29LV160AB programing in h-jtag?
Post by giovaniluigi » Tue Nov 29, 2011 6:17 am
I read the manual in CD and I followed it to install WinCE.
The first thing is to enter supervivi command and type: bon part 0 320k 2368k
This is the result:
Is this normal ?
Why all the blocks are BAD ?
Post by esky-sh » Tue Nov 29, 2011 8:34 pm
esky-sh wrote:1. Here is a steps/guide for how to update nand flash for wince(You can also find it in your user guide)
viewtopic.php?f=6&t=406
1. Please select correct supervivi image for different nand flash size on your board
supervivi-64M for nand flash 64M
supervivi-128M for nand flash >64M
2. Please re-connect USB when you load wince image to your board
you may plug out and then plug in USB cable after you type ''w'' comand.
giovaniluigi
Post by giovaniluigi » Wed Nov 30, 2011 4:38 pm
It's working now. :D
Sorry I had not understood the part of disconnecting and reconnecting. :mrgreen:
I tought that you were talking to remove after having sent the NK.bin
Well, it's perfect now. :D
I need to talk with you "esky-sh"
I want to buy more 2 LCDs with cables (4,3") to include in another boards that I have here with smaller LCDs.
Also I would like to know how to buy other things for this kit... and more kits...
So if you can send your email, messenger or skype for commercial messages I will apreciate.
Thanks. Sorry for not having understood but sometimes I got confused. :oops:
