adapter card to connect LCD
ferandec
Post by ferandec » Mon Apr 19, 2010 10:24 pm
Does someone know where to buy the little adapter card between the Hirose LCD connector located on the mini2440 mother board and the Flat Flexible Cable (FFC) ?
Due to a electrical contact problem, mine is out of order and I don't have the necessary soldering material to repair it (I have tried with a classical soldering iron and my card is now no longer usable...).
Is there an other solution to make a direct link between the Hirose DF9-41S-1V connector on the mini2440 and the FFC connector located on the LCD ?
Thanks in advance
Re: adapter card to connect LCD
Post by esky-sh » Tue Apr 20, 2010 8:29 pm
you can contact the seller, they may have a solution.
