QQ2440 image problem
IDrenth
Post by IDrenth » Wed Nov 25, 2009 8:02 pm
There is problem with qq2440 version
The new supervivi-64M doesn't work:
-The xmodem transfer is switch off.
-The USB connection doesn't work any more.
The origenel Supervivi doesn't support the new mini2440 image .bin files.
If you use the .nbo file you get it running but afther restarting the OS is gone.
Re: QQ2440 image problem
Post by nicolas » Thu Nov 26, 2009 12:21 pm
The reason the .nb0 are gone after restart is because the nb0 files are runtime ready images.
Theyr copied into ram to run.
As for the supervivi not working, im not sure about the qq2440.
It should not change much in terms of vivi, as the usb is the same and the such.
Which supervivi-64M did you try? ie the foldername it came from.
IDrenth
Post by IDrenth » Thu Nov 26, 2009 1:56 pm
I use the the version of mini20090817.
If I want to sent the .bin version I get a error.
Now, Downloading [ADDRESS:30058000h,TOTAL:26178241]
Downloaded file at 0x30000000, size = 26178231 bytes
Mark bad blocks as unused ......
Mark Block 19 as unused, has mark 1 blocks
Extract wince image throught USB ......
OEMMultiBINNotify: Download BIN file information:
[0]: Base Address=0x80200000 Length=0x197bad0
OEMVerifyMemory: StartAddr: 0x80200000, Length:0x197bad0
*** Downloading UNKNOWN image type ***
ERROR: Checksum failure (expected=0x1eb computed=0x14)
****** Checksum failure on record 0, ABORT!!! ******
Extract wince image failed, ret = 0
Post by nicolas » Thu Nov 26, 2009 3:35 pm
Right, because the new WinCE images are not compatible with the old Supervivi.
(Would have been more proper if you made this post in the WinCE forum or at least said it was WinCE related - i knew that, but others may not have)
Does your pc detect the USB device ?
Does DNW say USB 'ok' ?
IDrenth
Post by IDrenth » Thu Nov 26, 2009 3:37 pm
On the top I also say the new supervivi doesn't support USB any more.
So I hope sombody change this for the QQ2440
A Hardware Workaround
Post by esky-sh » Sun Nov 29, 2009 9:51 pm
You can pullup usb enable signal to let the board recognized by DNW when it connected to PC. This will allow latest supervivi-64M work on QQ2440 board.
IDrenth
Post by IDrenth » Mon Nov 30, 2009 1:56 pm
what do you mean with the red cross?
Disconnect and connect the 5VDC on the 4K7 or do you mean connect also the 5VDC on the front of resistor R29 ?
this is only away to offer rule the signal from the s3c2440 USB_EN.
So the supervivi doesn't give the 5V for this ??? I think its better to solve this in the software manner instead of change the hardware ?
Its little strange for me, but I will try it out.
afther I got the answer on the connect 5VDC with the USB_EN or with out the USB_EN.
Post by esky-sh » Mon Nov 30, 2009 4:27 pm
The D+ pin of USB device will be pulled to high when a device connect to PC. On QQ2440 board this feature implemented by USB_EN1 signal(controled by software) but unfortunately latest supervivi-64M ignore it. So we need manually pull D+ pin to high by hardware.
IDrenth
Post by IDrenth » Tue Dec 01, 2009 9:44 am
did you test it on the QQ2440 before ??
I try it out and the usb DNW say connection oke.
the Nboot_a70 is no problem to send.
but I can't send any nk_a70.bin to it. The DNW freeze to send and nothing happend.
Post by esky-sh » Thu Dec 03, 2009 1:32 am
Hi, You can try this version of supervivi for QQ2440 :P
supervivi-QQ2440.rar
(79.74 KiB) Downloaded 478 times
Users browsing this forum: No registered users and 9 guests
