Problems with installation WinCE
dgin
Post by dgin » Sun Oct 03, 2010 4:05 am
I started from NOR
1.I have chosen the command [f] (nand scrub).After that has pressed a key 'y'.
But has as the result - scrub aborted.
2.After that has chosen the command [n] Download Nboot.nb0 for WinCE,
and ported Nboot_A70.nb0 into nand.
3.After that has chosen the command [w] Download WinCE NK.nb0,
and ported NK_A70.nb0 into nand.
4.After all it I started from nand
That I should make. Help me
Re: Problems with installation WinCE
Post by esky-sh » Sun Oct 03, 2010 4:25 am
You can burn wince image into nand flash in that way:
1. burn u-boot into your nand flash by 'v' command
2. switch to nand boot mode
3. boot from u-boot nand
4. burn nboot by 'n' command
5. burn wince by 'w' command
6. power cycle the board
dezso
Post by dezso » Sun May 01, 2011 7:18 pm
OMG
I need a CD or a CD image contain all the latest WinCE BSP !!!!
Need it now !!, the one eBay seller sent me was damaged during shipping or it was not verified after burn, it's completely unreadable, tested on multiple machine !!!
Manged to download from FTP one of the older version but BOOT-LOADER not working "LCD pin not turned on" and touchscreen not functioning !!!
Please put it on the FTP now, ready to send this package back and pay $$ more for local distributor..
Post by esky-sh » Mon May 02, 2011 1:34 am
dezso wrote:OMG
The contents in FTP are same as it in DVD-ROMs. Please post the isssues you met and let us know what the problems need to be addressed.
dezso
Post by dezso » Mon May 02, 2011 10:11 am
Please show me where is the BSP for 6410 on the ftp
tq6410-20110319 dont have BPS
tq6410-20101007 dont have BSP
tq6410-20100925 dont have BSP
tq6410-20110319 have BSP files buut no setup for it, that not the complete package.
Tried to install other 6410 BSP than copy over this files found in FTP, no change, Bootloader produced not working, nb0 works if I use other bootloaders but touchscreen not working, power management not working...
I have changed the option.h for my LCD type A70
//#define LCD_N43
//#define LCD_T35
//#define LCD_X35
//#define LCD_L80
#define LCD_A70
//#define LCD_VGA1024768
//#define LCD_VGA800600
//#define LCD_VGA640480
//#define LCD_EZVGA
and
smdk6410.bat
set BSP_NOTOUCH=
set BSP_NOTOUCH_ADC=1
set BSP_NOTOUCHCOM=
set BSP_NOTOUCH_1WIRE=
please advice how to fix this, I need to make my own wince6 image...
Than I can continue to work on my SD
Post by esky-sh » Mon May 02, 2011 6:03 pm
dezso wrote:Please show me where is the BSP for 6410 on the ftp
That means there is no changes in WinCE for this update. We just do not want to upload too many copies for the same content.
dezso wrote: tq6410-20110319 have BSP files buut no setup for it, that not the complete package.
viewtopic.php?f=17&t=437
dezso wrote: Tried to install other 6410 BSP than copy over this files found in FTP, no change, Bootloader produced not working, nb0 works if I use other bootloaders but touchscreen not working, power management not working...
//#define LCD_N43
//#define LCD_T35
//#define LCD_X35
//#define LCD_L80
#define LCD_A70
//#define LCD_EZVGA
and
smdk6410.bat
set BSP_NOTOUCH=
set BSP_NOTOUCHCOM=
please try configuraion in this form:
set BSP_NOTOUCH=
set BSP_NOTOUCHCOM=1
set BSP_NOTOUCH_1WIRE=1
dezso
Post by dezso » Tue May 03, 2011 10:56 am
Yes I changed it.
Any IDEA why is the Buzzer constantly on, and why is the LCD backlight not turning off after the set time in display config?
dezso
Post by dezso » Tue May 03, 2011 9:39 pm
I have spend 7hr installing new OS xp32bit, vs2005, all ms wince6-r3, step by step, updates, patches....
The image produced not working properly.
Buzzer constantly on..... why ?
Backlight can't be controlled and touchscreen not working.
my 7' A70 works fine with mini2440
There is some port setting are screwed here..
Friendly ARM button app not working, and LED-Test app will not control the LED's, all four steady on after power on.
What now?
dezso
Post by dezso » Tue May 03, 2011 10:43 pm
Loaded Qtopia 2.2.0 the touchscreen works and the ADC stop buzzing, so there is must be a problem with the BSP setting somewhere.
Post by esky-sh » Wed May 04, 2011 3:39 am
dezso wrote:Loaded Qtopia 2.2.0 the touchscreen works and the ADC stop buzzing, so there is must be a problem with the BSP setting somewhere.
Could you have a test with tq6410-20100905/images/wince/NK_A70.nb0?
