Linux&Android Installation on TQ6410
Post by esky-sh » Wed May 11, 2011 11:15 pm
For Linux&Android installation on TQ6410, here are recommend steps:
1. Switch to nor boot mode and power cycle
2. Format nand flash -- 'f' command
3. Install u-boot in nand flash -- 'v' command
4. Switch to nand boot mode and power cycle
5. Install linux kernel -- 'k' command
6. Install rootfs -- 'y' command
*Note:
Ensure your u-boot bootarg setting like this, when you try to boot Android
root=/dev/mtdblock2 rootfstype=yaffs2 init=/linuxrc console=ttySAC0,115200
geha1984
Re: Linux&Android Installation on TQ6410
Post by geha1984 » Thu May 12, 2011 7:13 am
NAND Flash size: 256 MiB
Enter your Selection:f
NAND scrub: device 0 whole chip
Warning: scrub option will erase all factory set bad blocks!
There is no reliable way to recover them.
Use this command only for testing purposes if you
are sure of what you are doing!
Really scrub this NAND flash? <y/N>
scrub aborted
what is this????
after android installation:
s3c-nand: ECC uncorrectable error detected
block 213 is bad
block 214 is bad
block 273 is bad
block 1463 is bad
block 1497 is bad
yaffs_read_super: isCheckpointed 0
switch_root: bad init /sbin/init: No such file or directory
Kernel panic - not syncing: Attempted to kill init!
Post by esky-sh » Thu May 12, 2011 6:13 pm
geha1984 wrote:NAND Flash size: 256 MiB
scrub aborted
what is this????
viewtopic.php?f=17&t=412
dezso
Post by dezso » Sat May 14, 2011 11:05 am
Used exact procedure listed here, loaded fine, stated fine.
Files from ftp !
I have not owned any android device before, i'm finding the performance extremely poor, lan not working, I don't have wifi for it, video sample slow and choppy.
Fell like if I load Windows7 on a PII pc, is it the hardware? need better cpu/ram or this build is bad ?
Users browsing this forum: No registered users and 8 guests
