Angstrom drivers - update
samertfl
Re: Angstrom drivers - update
Post by samertfl » Tue Oct 04, 2011 6:51 am
that is true and my u-boot will work fine with my customized uImage with the changes mentioned but the touch screen will not work
Post by esky-sh » Tue Oct 04, 2011 6:30 pm
samertfl wrote:that is true and my u-boot will work fine with my customized uImage with the changes mentioned but the touch screen will not work
So why don't you have a check with the changes you made inside u-boot source code? This would be a simple way to fix your problem instantly. I guess there is only some configurations needed for pin mux of SPI.
samertfl
Post by samertfl » Wed Oct 05, 2011 5:47 am
As ive asked a number of times and will ask again have you yourself got the screen to work with Angstrom and NOT Android?
Post by esky-sh » Wed Oct 05, 2011 8:12 pm
The touch screen is a linux driver. It should be easy to work with Angstrom if it already work on your linux/android. So I suggest you to have some check with your u-boot setting first.
samertfl
Post by samertfl » Thu Oct 06, 2011 5:53 am
If that is true please provide a compiled version of u-boot and angstrom to test?
Post by esky-sh » Fri Oct 07, 2011 3:15 am
I will check with the support of Angstrom and update you soon.
samertfl
Post by samertfl » Fri Oct 07, 2011 5:10 am
thank you. Ill wait
kgy
Post by kgy » Sun Dec 25, 2011 9:57 am
I have a Beagleboard C4 with Angstrom (kernel 2.6.32). Everything works, except the tuchscreen.
I found a lot of information on the net about the touchscreen, but most of them are outdated, or describes a specific case. All the information i found is: "copy it from Android".
I see that there is a ads7846 driver in the kernel (this is necessary for touchscreen, AFAIK), but it does not work.
Is there a description which contains all information for Beagleboard to use the touchscreen (gpio settings, u-boot settings, kernel config, etc)?
Is ads7846 enough? Will the Angstrom support it in the near future?
Thanx inadvance
Gyorgy Kovesdi
kgy
Post by kgy » Sun Jan 22, 2012 8:20 am
I am stuck in the touchscreen problem yet with Angstrom and Beagleboard C4.
I tried the u-boot from ftp site but the ads7846 kernel driver does not work.
Any help would be appreciated
Gyorgy Kovesdi
Users browsing this forum: No registered users and 6 guests
