Ubuntu 12.04 LTS works on Pandaboard & ES with Beadaframe
Posted: Sun Aug 26, 2012 12:13 am
A technical discussion forum for all embedded development stuff!
https://www.esky-sh.com/bbs/
yesesky-sh wrote: 1. The information from the support forum, regarding board rework is not clear for pandaboard es rev B1 - i think all the resistors needed are already populated, soldering the 2 jacks bill be enough, right?
which software image you were using in this case?2. on system power up we get a short white flashing from the beada, then it turns black, nothing more. i booted with bootargs=vram=32M fixrtc mem=1G@0x80000000 root=/dev/mmcblk0p2 rw console=ttyO2,115200n8 rootwait omapfb.mode=dvi:800x480MR-16@60 omapdss.def_disp=dvi
We provide source code for ubuntu and android, please check with our ftp for downloading.3. which linux kernel patches are needed for beada frame, and where can i get them. we have to compile our own kernels, so i need this information...
Notification words in shipping email is generic, so there is no setup cd for this BeadaFrame part.4. in shipping notification you mentioned a setup cd from ftp server - i could not find it there, can you provide a link please
Ubuntu 12.04 LTS should works well on Pandaboard ES, we already had customers with same configuration as yours. Please provide more details for your failure like logs.5. is there a linux test image out there for pandaboard es, where i can check if the setup works? i tried it like in viewtopic.php?f=19&t=531 , but the system hangs on uncompressing linux
