1. \AM33X_BSP\SRC\DRIVERS\UART\uart.reg
AM33X UART driver(am33x_uart.dll) retrieves pinmux information from corresponding registry entries
;-- UART Driver -----------------------------------------------------------------
IF BSP_AM33X_UART1
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\UART1]
"Prefix"="COM"
"Dll"="am33x_uart.dll"
"DeviceArrayIndex"=dword:1
"Index"=dword:1
"Order"=dword:9
"MemBase"=multi_sz:"44E05000"
"MemLen"=multi_sz:"00001000"
"PowerFlags"=dword:00000103 ; send pre/post device state changes
"RxBuffer" = dword:2000
"TxDmaRequest"=dword:ffffffff ; TxDma has issues after RX of break, disabled with ffffffff
"TxDmaBufferSize"=dword:2000 ; Size of DMA transmit buffer
"RxDmaRequest"=dword:ffffffff ; S_DMA_49 RX DMA Request Line, use ffffffff to disable RX DMA
"RxDmaBufferSize"=dword:2000 ; Size of DMA receive buffer
"RtsCtsEnable"=dword:0 ; 1=enable RTS/CTS handshake support, 0=disable
"HWMode"=dword:0 ; Use hardware auto RTS/CTS
"Frequency"=dword:2DC6C00 ; UART operation freq, 48000000
; PMCLASS_PMEXT_GUID, CE_DRIVER_POWER_MANAGEABLE_GENERIC_GUID
"IClass"=multi_sz:"{0AE2066F-89A2-4D70-8FC2-29AEFA68413C}",
"{A32942B7-920C-486b-B0E6-92A702A99B35}"
ENDIF BSP_AM33X_UART1
2. \PLATFORM\COMMON\SRC\SOC\COMMON_TI_V1\COMMON_TI_AMXX\SERIAL\pdd_common.c
// Function: HWInit
// This function initializes a serial device and it returns information about
// it.
static
PVOID
HWInit(
ULONG context,
PVOID pMdd,
PHWOBJ pHWObj
BOOL rc = FALSE;
UARTPDD *pPdd = NULL;
PHYSICAL_ADDRESS pa;
SOC_UART_REGS *pUartRegs;
DEBUGMSG(ZONE_OPEN||ZONE_FUNCTION, (
L"+HWInit(%s, 0x%08x, 0x%08x\r\n", context, pMdd, pHWObj
// Allocate SER_INFO structure
pPdd = LocalAlloc(LPTR, sizeof(UARTPDD));
if (pPdd == NULL) goto cleanUp;
memset(pPdd, 0x00, sizeof(UARTPDD));
// Read device parameters
if (GetDeviceRegistryParams(
(LPCWSTR)context, pPdd, dimof(s_deviceRegParams), s_deviceRegParams
) != ERROR_SUCCESS)
DEBUGMSG(ZONE_ERROR, (L"ERROR: HWInit: "
L"Failed read driver registry parameters\r\n"
goto cleanUp;
rc = CreateParentBus(pPdd, context);
if (rc == FALSE)
goto cleanUp;
rc = FALSE;
// Retrieve device index
pPdd->DeviceID = SOCGetUartDeviceByIndex(pPdd->UARTIndex);
if (pPdd->DeviceID == OMAP_DEVICE_NONE)
L"Failed to retrieve valid device ID for this UART\r\n"
goto cleanUp;
// Perform pads configuration
if (!RequestDevicePads(pPdd->DeviceID))
L"Failed to request pads\r\n"
goto cleanUp;
// File: soccfg.c
// Configuration file for the device list
#include "am33x.h"
#include "soc_cfg.h"
#include "omap_devices_map.h"
#include "am33x_clocks.h"
#include "omap_cpgmac_regs.h"
DWORD SOCGetGPIODeviceByBank(DWORD index)
switch (index)
case 1: return AM_DEVICE_GPIO0;
case 2: return AM_DEVICE_GPIO1;
case 3: return AM_DEVICE_GPIO2;
case 4: return AM_DEVICE_GPIO3;
default: return OMAP_DEVICE_NONE;
DWORD SOCGetSDHCDeviceBySlot(DWORD index)
switch (index)
case 1: return AM_DEVICE_MMCHS0;
case 2: return AM_DEVICE_MMCHS1;
case 3: return AM_DEVICE_MMCHS2;
DWORD SOCGetMCSPIDeviceByBus(DWORD index)
switch(index)
case 1: return AM_DEVICE_MCSPI0;
case 2: return AM_DEVICE_MCSPI1;
DWORD SOCGetI2CDeviceByBus(DWORD index)
switch(index)
case 1: return AM_DEVICE_I2C0;
case 2: return AM_DEVICE_I2C1;
case 3: return AM_DEVICE_I2C2;
DWORD SOCGetUartDeviceByIndex(DWORD index)
switch(index)
case 1: return AM_DEVICE_UART0;
case 2: return AM_DEVICE_UART1;
case 3: return AM_DEVICE_UART2;
case 4: return AM_DEVICE_UART3;
case 5: return AM_DEVICE_UART4;
case 6: return AM_DEVICE_UART5;
DWORD SOCGetGPMCAddress(DWORD index)
UNREFERENCED_PARAMETER(index);
return AM33X_GPMC_REGS_PA;
void SOCGetDSSInfo(DSS_INFO* pInfo)
pInfo->DSSDevice = AM_DEVICE_LCDC;
pInfo->TVEncoderDevice = (DWORD)NULL;
pInfo->DSS1_REGS_PA = (DWORD)NULL;
pInfo->DISC1_REGS_PA = (DWORD)NULL;
pInfo->VENC1_REGS_PA = (DWORD)NULL;
pInfo->DSI_REGS_PA = (DWORD)NULL;
pInfo->DSI_PLL_REGS_PA = (DWORD)NULL;
UINT32 SOCGetSysFreqKHz(void)
return 24000;
\PLATFORM\COMMON\SRC\SOC\COMMON_TI_V1\COMMON_TI\OAL\OMAP_OALPADCFG\oalpadcfg.c
BOOL RequestDevicePads(OMAP_DEVICE device)
BOOL rc = FALSE;
const PAD_INFO* p = BSPGetDevicePadInfo(device);
if (p)
rc = RequestAndConfigurePadArray(p);
return rc;
// NOTE : this function is not optimized at all. It's intended to be used very seldom
BOOL RequestAndConfigurePadArray(const PAD_INFO* padArray)
BOOL rc = TRUE;
int i = 0;
PadCfgLock();
// Check that all pads are valid and released
i=0;
while (rc && (padArray[i].padID != (UINT16) -1))
int padIndex;
padIndex = FindPad(padArray[i].padID);
if (padIndex == -1)
goto error;
if (padIndex >= g_NbPads)
ASSERT(0);
goto error;
if (g_bspPadInfo[padIndex].inUse)
goto error;
i++;
// Request and Configure all pads
i = 0;
int padIndex;
g_bspPadInfo[padIndex].inUse = 1;
SOCSetPadConfig(padArray[i].padID,(UINT16)padArray[i].Cfg);
i++;
PadCfgUnlock();
return TRUE;
error:
PadCfgUnlock();
return FALSE;
\PLATFORM\COMMON\SRC\SOC\COMMON_TI_V1\AM33X\INC\am33x_clocks.h
typedef enum {
AM_DEVICE_ADC_TSC = 0, /* WKUP */ /* 0 */
AM_DEVICE_CONTROL,
AM_DEVICE_DEBUGSS,
AM_DEVICE_GPIO0,
AM_DEVICE_I2C0,
AM_DEVICE_L4WKUP,
AM_DEVICE_SMARTREFLEX0,
AM_DEVICE_SMARTREFLEX1,
AM_DEVICE_TIMER0,
AM_DEVICE_TIMER1,
AM_DEVICE_UART0, /* 10 */
AM_DEVICE_WDT0,
AM_DEVICE_WDT1,
AM_DEVICE_WKUP_M3,
AM_DEVICE_AES0, /* PER */
AM_DEVICE_AES1,
AM_DEVICE_CLKDIV32K,
AM_DEVICE_CPGMAC0,
AM_DEVICE_DCAN0,
AM_DEVICE_TIMER7,
AM_DEVICE_TPCC,
AM_DEVICE_TPTC0,
AM_DEVICE_TPTC1,
AM_DEVICE_TPTC2,
AM_DEVICE_UART1,
AM_DEVICE_UART2, /* 70 */
AM_DEVICE_UART3,
AM_DEVICE_UART4,
AM_DEVICE_UART5,
AM_DEVICE_USB0,
AM_DEVICE_BITBLT, /* GFX */
AM_DEVICE_GFX,
AM_DEVICE_MMU,
AM_DEVICE_MMUCFG,
AM_DEVICE_MPU, /* MPU */
AM_DEVICE_RTC, /* 80 */
AM_DEVICE_CEFUSE,
AM_DEVICE_EFUSE,
AM_DEVICE_COUNT,
/* following devices are needed for pinmux */
/* when adding new device here, dont forget to fill the s_rgDeviceRemapTable in prcm_device.h */
AM_DEVICE_NAND, /* same as GPMC */
AM_DEVICE_NOR, /* same as GPMC */
AM_DEVICE_BKL, /* GPIO */
AM_DEVICE_END /* this should be the last one */
} AM33X_DEVICE_ID;
\PLATFORM\AM33X_BSP\SRC\BSP_COMMON\BSP_PADCFG\bsp_padcfg.c
* Update the structure with the modules present in the general purpose
* board and the profiles in which the modules are present.
* If the module is physically present but if it is not available
* in any of the profile, then do not update it.
* For eg, nand is avialable only in the profiles 0 and 1, whereas
* UART0 is available in all the profiles.
const EVM_PIN_MUX GP_BOARD_PIN_MUX[] = {
{ ADCTSCPads, AM_DEVICE_ADC_TSC, PROFILE_0 | PROFILE_1 | PROFILE_2 | PROFILE_7, DEV_ON_DGHTR_BRD},
{ BKLPads, AM_DEVICE_BKL, PROFILE_0 | PROFILE_1 | PROFILE_2 | PROFILE_7, DEV_ON_DGHTR_BRD},
{ I2C0Pads, AM_DEVICE_I2C0, PROFILE_ALL, DEV_ON_BASEBOARD},
{ I2C1Pads, AM_DEVICE_I2C1, PROFILE_ALL & ~PROFILE_2 & ~PROFILE_4, DEV_ON_BASEBOARD},
{ LCDCPads, AM_DEVICE_LCDC, PROFILE_0 | PROFILE_1 | PROFILE_2 | PROFILE_7, DEV_ON_DGHTR_BRD}, //although its separate LCD board, use BaseBoard as location; will use profile info to know if LCD is valid or not
{ MCASP1Pads, AM_DEVICE_MCASP1, PROFILE_0 | PROFILE_3, DEV_ON_DGHTR_BRD},
{ MMC0Pads, AM_DEVICE_MMCHS0, PROFILE_ALL & ~PROFILE_5, DEV_ON_BASEBOARD},
{ MMC0_NoCD_Pads, AM_DEVICE_MMCHS0, PROFILE_5, DEV_ON_BASEBOARD},
{ MMC1Pads, AM_DEVICE_MMCHS1, PROFILE_2, DEV_ON_DGHTR_BRD},
{ MMC2Pads, AM_DEVICE_MMCHS2, PROFILE_4, DEV_ON_DGHTR_BRD},
{ NANDPads, AM_DEVICE_NAND, PROFILE_ALL & ~PROFILE_2 & ~PROFILE_3, DEV_ON_DGHTR_BRD},
{ NORPads, AM_DEVICE_NOR, PROFILE_3, DEV_ON_DGHTR_BRD},
{ RGMIIMultiplePhyPads, AM_DEVICE_CPGMAC0, PROFILE_1 | PROFILE_2 | PROFILE_4 | PROFILE_6, DEV_ON_DGHTR_BRD},
{ RGMIISinglePhyPads, AM_DEVICE_CPGMAC0, PROFILE_0 | PROFILE_3 | PROFILE_5 | PROFILE_7, DEV_ON_BASEBOARD},
{ SPI0Pads, AM_DEVICE_MCSPI0, PROFILE_2, DEV_ON_DGHTR_BRD},
{ UART0Pads, AM_DEVICE_UART0, PROFILE_ALL, DEV_ON_BASEBOARD},
{ USB0Pads, AM_DEVICE_USB0, PROFILE_ALL, DEV_ON_BASEBOARD},
{0},
const EVM_PIN_MUX * AM335x_EVM_PIN_MUX[] = {
GP_BOARD_PIN_MUX,
NULL,
NULL,
NULL,
PAD_INFO* BSPGetAllPadsInfo()
return g_allowedPadCfg;
const PAD_INFO* BSPGetDevicePadInfo(OMAP_DEVICE device)
DWORD i=0;
EVM_PIN_MUX * board_pin_mux = AM335x_EVM_PIN_MUX[g_dwBoardId];
if (board_pin_mux == NULL) {
//OALMSG(1,(L"BSPGetDevicePadInfo: Invalid board ID %d\r\n",g_dwBoardId));
return NULL;
for (i = 0; board_pin_mux[i].padInfo != 0; i++) {
//look for the device
if (board_pin_mux[i].device != device)
continue;
//found the device; now check the profile
if ((g_dwBoardProfile == PROFILE_NONE) || (board_pin_mux[i].profile & g_dwBoardProfile)) {
//profile match found; now check if device on daugter card and if daugter card present
if (((board_pin_mux[i].device_on == DEV_ON_DGHTR_BRD) && (g_dwBoardHasDcard == TRUE)) ||
(board_pin_mux[i].device_on == DEV_ON_BASEBOARD))
return board_pin_mux[i].padInfo;
//OALMSG(1,(L"BSPGetDevicePadInfo: No Device Pad Info found for device %d\r\n",device));
return NULL;
\PLATFORM\AM33X_BSP\SRC\DRIVERS\KEYPAD\gpio_keypad.c
// Local Definitions
#define VK_KEYS 256
#define DWORD_BITS 32
#define NB_KEYS 8
UCHAR vKeys[NB_KEYS] = {VK_DOWN, VK_UP, VK_LEFT, VK_RIGHT, L'1', L'2', L'3', VK_RETURN};
static const PAD_INFO KeypadPads[] = {KEYPAD_PADS END_OF_PAD_ARRAY};
// Device registry parameters
static const DEVICE_REGISTRY_PARAM g_deviceRegParams[] = {
L"Priority256", PARAM_DWORD, FALSE, offset(KPD_DEVICE, priority256),
fieldsize(KPD_DEVICE, priority256), (VOID*)100
L"SamplePeriod", PARAM_DWORD, FALSE, offset(KPD_DEVICE, samplePeriod),
fieldsize(KPD_DEVICE, samplePeriod), (VOID*)40
L"DebounceTime", PARAM_DWORD, FALSE, offset(KPD_DEVICE, debounceTime),
fieldsize(KPD_DEVICE, debounceTime), (VOID*)0x50
L"FirstRepeat", PARAM_DWORD, FALSE, offset(KPD_DEVICE, firstRepeat),
fieldsize(KPD_DEVICE, firstRepeat), (VOID*)500
L"NextRepeat", PARAM_DWORD, FALSE, offset(KPD_DEVICE, nextRepeat),
fieldsize(KPD_DEVICE, nextRepeat), (VOID*)125
// Local functions
BOOL KPD_Deinit(DWORD context);
static DWORD KPD_Thread(VOID *pParam);
DWORD KPD_Init(LPCTSTR szContext, LPCVOID pBusContext)
// Called by device manager to initialize device.
// int i;
DWORD rc = (DWORD)NULL;
KPD_DEVICE *pDevice = NULL;
UNREFERENCED_PARAMETER(pBusContext);
DEBUGMSG(ZONE_FUNCTION, (L"+KPD_Init(%s, 0x%08x)\r\n", szContext, pBusContext));
if (RequestAndConfigurePadArray(KeypadPads)==FALSE){
DEBUGMSG(ZONE_ERROR, (L"ERROR: KPD_Init: Cannot configure keypad pads\r\n"));
goto cleanUp;
pDevice = (KPD_DEVICE *)LocalAlloc(LPTR, sizeof(KPD_DEVICE));
if (pDevice == NULL) {
DEBUGMSG(ZONE_ERROR, (L"ERROR: KPD_Init: Failed allocate KDP driver structure\r\n"));
goto cleanUp;
memset(pDevice, 0, sizeof(KPD_DEVICE));
pDevice->hGpio = GPIOOpen();
if (pDevice->hGpio == NULL){
DEBUGMSG(ZONE_ERROR, (L"ERROR: KPD_Init: Failed to open GPIO driver\r\n"));
goto cleanUp;
GPIOSetMode(pDevice->hGpio, GPIO_53, GPIO_DIR_OUTPUT);
GPIOSetMode(pDevice->hGpio, GPIO_54, GPIO_DIR_OUTPUT);
GPIOSetMode(pDevice->hGpio, GPIO_57, GPIO_DIR_INPUT);
GPIOSetMode(pDevice->hGpio, GPIO_58, GPIO_DIR_INPUT);
GPIOSetMode(pDevice->hGpio, GPIO_59, GPIO_DIR_INPUT);
GPIOSetMode(pDevice->hGpio, GPIO_2, GPIO_DIR_INPUT);
GPIOSetMode(pDevice->hGpio, GPIO_3, GPIO_DIR_INPUT);
GPIOSetBit(pDevice->hGpio, GPIO_53);
GPIOClrBit(pDevice->hGpio, GPIO_54);
InitializeCriticalSection(&pDevice->cs);
if (GetDeviceRegistryParams(szContext, pDevice, dimof(g_deviceRegParams), g_deviceRegParams)
!= ERROR_SUCCESS) {
DEBUGMSG(ZONE_ERROR, (L"ERROR: KPD_Init: Failed read KPD driver registry parameters\r\n"));
pDevice->priority256=100;
pDevice->samplePeriod=40;
pDevice->debounceTime=0x50;
pDevice->firstRepeat=500;
pDevice->nextRepeat=125;
// Pinmux config
// GPIOSetMode for all required GPIOs
if ((pDevice->hThread = CreateThread(NULL, 0, KPD_Thread, pDevice, 0,NULL)) == NULL) {
DEBUGMSG (ZONE_ERROR, (L"ERROR: KPD_Init: Failed create interrupt thread\r\n"));
goto cleanUp;
CeSetThreadPriority(pDevice->hThread, pDevice->priority256);
rc = (DWORD)pDevice;
cleanUp:
if (rc == 0) KPD_Deinit((DWORD)pDevice);
DEBUGMSG(ZONE_FUNCTION, (L"-KPD_Init(rc = %d\r\n", rc));
return rc;
DWORD KPD_Thread(VOID *pContext)
// int index;
KPD_DEVICE *pDevice = (KPD_DEVICE*)pContext;
DWORD timeout, time, ix;
DWORD change, mask;
UINT16 i;
USHORT data;
USHORT old_data;
UINT16 ic=0;
DWORD vkState[VK_KEYS/DWORD_BITS], vkNewState[VK_KEYS/DWORD_BITS];
KEYPAD_REMAP_STATE *pRemapState = NULL;
KEYPAD_REPEAT_STATE *pRepeatState = NULL;
BOOL keyDown;
UCHAR vk=0;
DEBUGMSG(ZONE_IST, (L"KPD - Start IntrThread\r\n"));
#if 1
// Init data
memset(vkState, 0, sizeof(vkState));
// Initialize remap informations
if (g_keypadRemap.count > 0) {
// Allocate state structure for remap
if ((pRemapState = LocalAlloc(LPTR, g_keypadRemap.count * sizeof(KEYPAD_REMAP_STATE))) == NULL) {
DEBUGMSG(ZONE_ERROR, (L" KPD_Thread: Failed allocate memory for virtual key remap\r\n"));
goto cleanUp;
// Initialize repeat informations
if (g_keypadRepeat.count > 0) {
if ((pRepeatState = LocalAlloc(LPTR, g_keypadRepeat.count * sizeof(KEYPAD_REPEAT_STATE))) == NULL){
DEBUGMSG(ZONE_ERROR, (L" KPD_Thread: Failed allocate memory for virtual key auto repeat\r\n"));
goto cleanUp;
#endif
timeout = pDevice->samplePeriod;
old_data = 0;
// Loop until we are not stopped...
while (!pDevice->bThreadExit) {
Sleep(timeout/2);
data = 0;
data |= (GPIOGetBit(pDevice->hGpio,GPIO_57)) ? 0x01 : 0;
data |= (GPIOGetBit(pDevice->hGpio,GPIO_58)) ? 0x02 : 0;
data |= (GPIOGetBit(pDevice->hGpio,GPIO_59)) ? 0x04 : 0;
GPIOSetBit(pDevice->hGpio, GPIO_54);
GPIOClrBit(pDevice->hGpio, GPIO_53);
Sleep(timeout/2);
data |= (GPIOGetBit(pDevice->hGpio,GPIO_57)) ? 0x08 : 0;
data |= (GPIOGetBit(pDevice->hGpio,GPIO_58)) ? 0x10 : 0;
data |= (GPIOGetBit(pDevice->hGpio,GPIO_59)) ? 0x20 : 0;
data |= (GPIOGetBit(pDevice->hGpio,GPIO_2)) ? 0 : 0x40;
data |= (GPIOGetBit(pDevice->hGpio,GPIO_3)) ? 0 : 0x80;
#if 0
mod_data = data ^ old_data;
for (i = 0, mask_data = 1; i<NB_KEYS; i++, mask_data <<= 1){
if (mod_data & mask_data){
if (data & mask_data){
RETAILMSG(1, (L" KPD_Thread: Key Down: 0x%x\r\n", vKeys[i] ));
keybd_event(vKeys[i], 0, 0, 0);
} else {
RETAILMSG(1, (L" KPD_Thread: Key Up: 0x%x\r\n", vKeys[i] ));
keybd_event(vKeys[i], 0, KEYEVENTF_KEYUP, 0);
![Laughing :lol:](./images/smilies/icon_lol.gif)
\PLATFORM\AM33X_BSP\SRC\DRIVERS\BACKLIGHT\gpio_backlight.cpp
BOOL
GPIO_Backlight::Initialize(
LPCTSTR szContext
L"+GPIO_Backlight::Initialize(%s)\r\n", szContext
BOOL rc = FALSE;
if (ParentClass::Initialize(szContext) == FALSE)
DEBUGMSG(ZONE_ERROR, (L"ERROR: TLED_Backlight::Initialize: "
L"Parent class failed to initialize\r\n"
goto cleanUp;
szContext, this, dimof(s_deviceRegParams), s_deviceRegParams
) != ERROR_SUCCESS)
DEBUGMSG(ZONE_ERROR, (L"ERROR: GPIO_Backlight::Initialize: "
L"Failed read gpio driver registry parameters\r\n"
goto cleanUp;
// GPIO pin not configured, tled only
if (m_gpioId == GPIO_NOT_USED)
L"GPIO_Backlight::Initialize: No GPIO pin allocated, continuing...\r\n"
rc = TRUE;
goto cleanUp;
m_hGpio = GPIOOpen();
if (m_hGpio == NULL)
L"Failed allocate GPIO handle\r\n"
goto cleanUp;
// setup for output mode
GPIOSetMode(m_hGpio, m_gpioId, GPIO_DIR_OUTPUT);
rc = TRUE;
cleanUp:
L"-GPIO_Backlight::Initialize(%s) == %d\r\n", szContext, rc
return rc;
