;; ; Check r9 for HS flag
;; cmp r9, #OEM_HIGH_SECURITY_HS
;; moveq r0, #OEM_HIGH_SECURITY_HS
;; movne r0, #OEM_HIGH_SECURITY_GP
; ; Jump to BootMain
; ldr sp, =(IMAGE_EBOOT_STACK_CA + IMAGE_EBOOT_STACK_SIZE)
; ; Jump to the C entrypoint.
; b main ; Jump to main.c::main(), never to return...
; ENTRY_END
; ; Include memory configuration file with g_oalAddressTable
; INCLUDE addrtab_cfg.inc
; END
void main()
/* hard coded to AM33x, run time detection can be added later */
g_CPUFamily = CPU_FAMILY_AM33X;
/* setup pinmux and clocks for Debug UART */
EnableDeviceClocks(BSPGetDebugUARTConfig()->dev,TRUE);
BootloaderMain();
BOOL OEMPlatformInit()
// This function provide platform initialization functions. It is called
// from boot loader after OEMDebugInit is called. Note that boot loader
// BootloaderMain is called from s/init.s code which is run after reset.
AM3XX_GPTIMER_REGS* pTimerRegs = OALPAtoUA(AM33X_GPTIMER2_REGS_PA);
static UCHAR allocationPool[512];
OALLocalAllocInit(allocationPool,sizeof(allocationPool));
/* add board detection logic here */
OALI2CInit(AM_DEVICE_I2C0);
detect_board_id_and_profile_info();
configure_evm_pin_mux();
EnableDeviceClocks(AM_DEVICE_TIMER2, TRUE);
/* Select the Master osc 24 MHZ as Timer2 clock source */
OUTREG32(OALPAtoUA(CLKSEL_TIMER2_CLK), 0x1);
OALLogSetZones( (1<<OAL_LOG_VERBOSE)|(1<<OAL_LOG_INFO)|(1<<OAL_LOG_ERROR)|
/*(1<<OAL_LOG_WARN) |(1<<OAL_LOG_FUNC)|*/(1<<OAL_LOG_IO) );
OALLog(L"\r\nTexas Instruments Windows CE EBOOT for AM33x, "
L"Built %S at %S\r\n", __DATE__, __TIME__);
OALLog(L"EBOOT Version %d.%d.%d, BSP " BSP_VERSION_STRING L"\r\n",
EBOOT_VERSION_MAJOR, EBOOT_VERSION_MINOR, EBOOT_VERSION_BUILD);
// TIMER_1
OUTREG32(&pTimerRegs->TCLR, 0); // stop timer
OUTREG32(&pTimerRegs->TIOCP, GPTIMER_TIOCP_SOFTRESET); // Soft reset GPTIMER
while ((INREG32(&pTimerRegs->TIOCP) & GPTIMER_TIOCP_SOFTRESET) != 0); // While until done
OUTREG32(&pTimerRegs->TSICR, GPTIMER_TSICR_POSTED); // Enable posted mode
// Start timer
OUTREG32(&pTimerRegs->TCLR, GPTIMER_TCLR_AR|GPTIMER_TCLR_ST);
while ((INREG32(&pTimerRegs->TWPS) & GPTIMER_TWPS_TCLR) != 0); // Wait until write is done
// Enable device clocks used by the bootloader
EnableDeviceClocks(AM_DEVICE_GPIO0,TRUE);
// configure i2c devices
//OALI2CInit(OMAP_DEVICE_I2C2);
//OALI2CInit(OMAP_DEVICE_I2C3);
GPIOInit();
OALLog(L"\r\nTI AM33X \r\n");
/* Initialize Device Prefix */
gDevice_prefix = BSP_DEVICE_AM33x_PREFIX;
g_ecctype = (UCHAR)dwEbootECCtype;
OALLog(L"\r\necc type:%d \r\n", g_ecctype);
// Done
return TRUE;
static BOOL KernelRelocate (ROMHDR *const pTOC);
BOOL OEMDebugInit();
BOOL OEMPlatformInit();
