Native compile Linux kernel on i.MX6ULL platform
NXP/Freescale Cortex-A7 i.MX6 Series System-On-Module
Post by esky-sh » Tue Aug 14, 2018 7:20 pm
Normally Linux kernel is built on various x86 architecture platform which we call it "cross-compiling" or "cross-development". In this test we will take a NXP i.MX6ULL 900MHz platform as build machine to make a native compiling of Linux kernel. And this make possible to compare the performance with the main stream x86 desktop.
Environment
Platform Name---Innostick 6
CPU-----------------i.MX6ULL 900MHz
RAM-----------------512MB DDR3L
eMMC---------------16GB
Network------------WiFi
====Pre-requirements==== ====CPU Info.====
debian@arm:/opt/innostick6$ lscpu
Architecture: armv7l
Byte Order: Little Endian
CPU(s): 1
On-line CPU(s) list: 0
Thread(s) per core: 1
Core(s) per socket: 1
Socket(s): 1
Model: 5
Model name: ARMv7 Processor rev 5 (v7l)
CPU max MHz: 900.0000
CPU min MHz: 198.0000
BogoMIPS: 13.63
Flags: half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae
====Debian Version====
debian@arm:/opt/innostick6$ cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 9 (stretch)"
NAME="Debian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/
====Install build-essential====
sudo apt-get install build-essential libncurses5-dev lzop
====Disk Info.====
debian@arm:/opt/innostick6$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 14G 2.5G 11G 20% /
devtmpfs 86M 0 86M 0% /dev
tmpfs 247M 0 247M 0% /dev/shm
tmpfs 247M 10M 237M 5% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 247M 0 247M 0% /sys/fs/cgroup
tmpfs 50M 4.0K 50M 1% /run/user/112
tmpfs 50M 0 50M 0% /run/user/1000
====Build U-Boot====
Get source code:
git clone https://source.codeaurora.org/external/imx/uboot-imx -b imx_v2017.03_4.9.88_2.0.0_ga
Start to Compile:
cd uboot-imx
make clean
make mx6ull_14x14_evk_defconfig
make
====Build Kernel====
Get source code:
git clone https://source.codeaurora.org/external/imx/linux-imx -b imx_4.9.88_2.0.0_ga
Start to compile
cd linux-imx
make imx_v7_defconfig
make
====Check Disk Info. Again====
debian@arm:/opt/innostick6/linux-imx$ df -h
/dev/root 14G 3.4G 9.6G 26% /
tmpfs 247M 6.9M 240M 3% /run
====Time Consumption====
Approximately 210 minutes
