Bad Partition Or Maybe Worst?
shoeprano27
Post by shoeprano27 » Fri May 10, 2024 6:12 am
hello. im having partition issues, it seems. i was to follow one of your guides posted here to repartition. what stopped me is that mines dont look the same as your screenshots. example, under rd3 linux files, in blue, it says removable D(F). your screenshot, in blue says partition1. also, regarding the file "snapshot beadapanel winusb", i have no idea where to even find that file. hoping that youd help me to fix this. i do have another sensor panel in use right now. but id rather use a simple single screen an elecrow screen with a raspberry pi.
Re: Bad Partition Or Maybe Worst?
Post by esky-sh » Fri May 10, 2024 7:03 am
What is your BP model? Can you post a picture here for what is difference found on your end? We can hardly understand what is the issue you were facing without detailed info.
shoeprano27
Post by shoeprano27 » Fri May 10, 2024 8:07 am
the screen is a NHBC05A Rev 1.0. attached is an INNOSTICK 6.
screen stays. when i have a tweezer in j2-1 and j2-2, still nothing no the screen, but on the computer with diskgenius, thats what i see.i dont know much else about it. i just think all the partitons are corrupted and need to reinstall everything back to factory settings. and what is the exact picture that you wanted to see on my end?
Post by esky-sh » Fri May 10, 2024 8:17 am
Please post a picture for the GUI of DG with BP connected.
shoeprano27
Post by shoeprano27 » Fri May 10, 2024 9:08 am
the picture in the first post is exactly that. my beadapanel connected to disk genius.
Post by esky-sh » Fri May 10, 2024 6:38 pm
I believe the image in your first post was not uploaded correctly.
屏幕截图 2024-05-11 103721.png (114.47 KiB) Viewed 49594 times
You can check if the file size exceed limits.
Users browsing this forum: No registered users and 175 guests
