c10paulkim wrote: ↑Sat Jul 19, 2025 1:38 pmHi, I stated I already tried the fix for the partition overflow issue, and now I get nothing from the device. The blue LED flashes a couple of times, the backlight turns on, but nothing displays and is not detected by the PC.
Need help on BeadaPanel 5C
Re: Need help on BeadaPanel 5C
c10paulkim
thanks! The troubleshooting has worked somewhat. I recovered the ext4 partition with the .pmf file, and put the .dtb and zimage in the E:. The screen does show the videos, but still doesn't show up in AIDA64. In Device manager, it shows that there is no driver installed...
If you had already installed Windows secondary monitor driver on your Windows host, then please uninstall it before you try to reconnect with AIDA64. These words are stated in BeadaPanel User Manual.c10paulkim wrote: ↑Sun Jul 20, 2025 8:38 pmthanks! The troubleshooting has worked somewhat. I recovered the ext4 partition with the .pmf file, and put the .dtb and zimage in the E:. The screen does show the videos, but still doesn't show up in AIDA64. In Device manager, it shows that there is no driver installed... Screenshot 2025-07-20 213748.png
c10paulkim
I did not install the secondary monitor driver, but did change some of the registry settings
delete this registry folder.c10paulkim wrote: ↑Mon Jul 21, 2025 12:09 pmI did not install the secondary monitor driver, but did change some of the registry settings
c10paulkim
yep matched the first couple of hex and deleted 2 folders, and it works now, thank you!
Users browsing this forum: No registered users and 189 guests
