DRM Driver Installation on Raspberry Pi
Posted: Wed Jul 31, 2024 4:46 am
In Linux world, DRM driver is becoming more and more popular. And BeadaPanel can support DRM driver as well. Take Raspberry Pi as example. In this procedure, we will install BeadaPanel as a secondary monitor, along with Raspberry Pi's main monitor.
Section 1, Install DRM Driver
Pre-requirements
  • A BeadaPanel Media Display
  • A Raspberry Pi Model 3B+(with Bookworm)
Procedures
  1. Connect Micro-USB cable with Raspberry Pi and BeadaPanel
  2. Login to Raspberry Pi main monitor
  3. Open a term window
  4. Compile the driver
    git clone -b rpi-6.6.y https://github.com/JT365/beada # download code
    cd beada/src
    make -C /usr/src/linux-headers-`uname -r`/ M=`pwd` modules # compile
  5. Install the driver
    sudo cp beadaDRM.ko /lib/modules/`uname -r`/kernel/drivers/gpu/drm/tiny/ # install module
    sudo depmod -a # load at bootup
Section 2, Screen Configuration on LXDE Desktop
Raspberry Pi will automatically discover an USB screen as soon as BeadaPanel plugin. There are steps needed for fine tune of screen appearance.
  1. Fine tune in Screen Configuration
    New discovered screen is in inactive state by default, so user should active it at first.
    Note: Manually click shutdown machine once you made changes into Gnome Screen Configuration, otherwise changes may get lost between power cycles.
  2. Fine tune in Appearance Settings
    Section 3, Set BeadaPanel as Primary Monitor in Xorg Environment
    In order to set BeadaPanel as a primary monitor to the Xorg environment, we will have to set BeadaPanel as a primary GPU device in a Xorg config file.
    Proceduces
    1. Open a term window
    2. Change to Xorg config folder
      cd /etc/X11/xorg.config.d/
    3. Create a new config file for BeadaPanel
      sudo nano 10-beada.conf
    4. Type the following text into it:
      Section "OutputClass"
        Identifier "beada"
        MatchDriver "beada"
        Driver "modesetting"
        Option "PrimaryGPU" "true"
      EndSection
    5. Press Control+x, you will get a prompt at the bottom of the screen asking you to "Save modified buffer (Answering No will DESTROY CHANGES)". Press y as we want to save the changes, and then Enter to Save Changes and exit the nano editor.
    6. Reboot the machine
    Section 4, Adjust backlight of BeadaPanel
    Proceduces
    2. Find current BeadaPanel DRM device
      pi@raspberrypi:~ $ ls /sys/class/drm/
      card0  card0-HDMI-A-1  card0-Writeback-1  card1  card1-USB-1  renderD128  version
    3. Check current BeadaPanel backlight level
      pi@raspberrypi:~ $ cat /sys/class/drm/card1-USB-1/backlight/brightness
      77
    4. Modify backlight:
      pi@raspberrypi:~ $ echo 99 >  /sys/class/drm/card1-USB-1/backlight/brightness
      99
