DRM Driver Installation on Ubuntu 24.04
Posted: Fri Aug 23, 2024 11:40 pm
In this procedure, we will install BeadaPanel as a secondary monitor, along with Ubuntu's main monitor.
Section 1, Install DRM Driver
Pre-requirements
  • A BeadaPanel Media Display
  • A Desktop PC(with Ubuntu 24.04 LTS)
Procedures
  1. Connect Micro-USB cable with Desktop PC and BeadaPanel
  2. Login to Ubuntu main monitor
  3. Open a term window
  4. Compile the driver
    git clone -b kub-6.8.0 https://github.com/JT365/beada # download code
    cd beada/src
    make -C /usr/src/linux-headers-`uname -r`/ M=`pwd` modules # compile
  5. Install the driver
    sudo cp beadaDRM.ko /lib/modules/`uname -r`/kernel/drivers/gpu/drm/tiny/ # install module
    sudo depmod -a # load at bootup
Section 2, Screen Configuration on GNOME Desktop
Wayland will not automatically discover an USB screen as soon as BeadaPanel plugin. Reboot your PC with BeadaPanel connected is required. When Ubuntu boots up, you will find it joins up your main monitor and BeadaPanel on GNOME desktop.
  1. Fine tune in Display Configuration
    Click to Settings|Displays
Section 3, Set BeadaPanel as Primary Monitor in Wayland Environment
Proceduces
  1. Go to Settings|Displays
  2. Select BeadaPanel as Primary display
  3. Click 'Apply' and then choose 'Keep changes' to current display setting
  4. BeadaPanel becomes primary monitor immediately
Section 4, Adjust backlight of BeadaPanel
Proceduces
  1. Open a term window
  2. Find current BeadaPanel DRM device
    esky-sh@NX-W-12:~$ ls /sys/class/drm/
    card0  card0-USB-1  card1  card1-VGA-1  renderD128  version
  3. Check current BeadaPanel backlight level
    esky-sh@NX-W-12:~$ cat /sys/class/drm/card0-USB-1/backlight/brightness
    90
  4. Modify backlight:
    esky-sh@NX-W-12:~$ echo 30 >  /sys/class/drm/card0-USB-1/backlight/brightness
    30
