I've uploaded my git tree based on the openmoko's u-boot branch, with support for the mini2440.
http://repo.or.cz/w/u-boot-openmoko/mini2440.git
U-boot works from nand, and allows loading via ethernet, mcc etc with pretty much all the modern extensions you would expect.
I'm working on doing the same for the kernel, so watch this space.
[ANN][MINI2440] modern u-boot (openmoko) git repository
Re: [ANN][MINI2440] modern u-boot (openmoko) git repository
I found that u-boot (openmoko) on real mini2440 does not skip bad blocks.
I load u-boot. Do 'nand scrub'. After do 'nand createbbt'
and after try erase and write area where found bad block and get write error.
U-Boot 1.3.2-dirty-moko12 (Mar 13 2009 - 14:37:14)
I2C: ready
DRAM: 64 MB
Flash: 2 MB
NAND: 64 MiB
Found Environment offset in OOB..
USB: S3C2410 USB Deviced
In: serial
Out: serial
Err: serial
MAC: 08:08:11:18:12:27
Hit any key to stop autoboot: 0
MINI2440 # nand scrub
NAND scrub: device 0 whole chip
Warning: scrub option will erase all factory set bad blocks!
There is no reliable way to recover them.
Use this command only for testing purposes if you
are sure of what you are doing!
Really scrub this NAND flash? <y/N>
Erasing at 0x1eb8000 -- 48% complete.
[b]NAND 64MiB 3,3V 8-bit: MTD Erase failure: -5[/b] <<--- bad block
Erasing at 0x3ffc000 -- 100% complete.
OK
MINI2440 # nand createbbt
Create BBT and erase everything ? <y/N>
[b]Skipping bad block at 0x01f38000 [/b]<<----- bad block
Creating BBT. Please wait ...
[b]Skipping bad block at 0x01f38000[/b] <<---- bad block
MINI2440 # nand bad
Device 0 bad blocks:
01f38000
MINI2440 # nand erase 0x1f30000 0x10000
NAND erase: device 0 offset 0x1f30000, size 0x10000
Erasing at 0x1f3c000 -- 100% complete.
OK
MINI2440 # nand write 0x32000000 0x1f30000 0x10000
NAND write: device 0 offset 0x1f30000, size 0x10000
[b]32768 bytes written: ERROR[/b] <<<---- get error
MINI2440 #
Check the second part of that page:
http://code.google.com/p/mini2440/wiki/MiniBringup
BTW could you move questions and such to my blog, or IRC ? here it's private, and I nobody else can benefit from my answering, I plan to stop answering on this forum soon.
Thank you buserror,
This was my fault.
If somone has same problem use 'nand write.e ...' cmd.
I found answer in MiniBringup.
My post closed.
This was my fault.
My post closed.
Users browsing this forum: No registered users and 20 guests
