2in1: qq2440 / mini2440 + linux 2.6.29 ! (upd: 26 March)
LeshaK
Re: 2in1: qq2440 / mini2440 + linux 2.6.29-rc5 - success
Post by LeshaK » Wed Feb 25, 2009 10:51 pm
new:
u-boot 1.3.2 for qq2440 & mini2440 (based on u-boot 1.3.2 mini2440 from Michel Pollet [buserror])
build for qq2440
make qq2440_config
make
mini2440
make mini2440_config
make
New universal patch for Linux 2.6.29-rc6 for qq2440 & mini2440.
add:
- audio support (get from Michel Pollet mini2440 kernel patch)
build for qq2440
make qq2440_defconfig
make
mini2440
make mini2440_defconfig
make
Attention!
new kernel patch will be work only with new u-boot 1.3.2
If you want to run with previous u-boot 1.1.6
open mach-qq2440.c
at the end of file, change:
#ifdef CONFIG_MACH_MINI2440
MACHINE_START(MINI2440, “MINI2440″)
#else
MACHINE_START(QQ2440, “QQ2440V3″)
#endif
on
MACHINE_START(S3C2440, “MINI2440″)
#else
MACHINE_START(S3C2440, “QQ2440V3″)
#endif
but all new patches will be for new u-boot!
for change old u-boot on new
put new u-boot on tftp and in command line u-boot enter
load new u-boot in ram
tftp 0x32000000 u-boot.bin
erase NAND
nand erase 0 0x30000
write new u-boot in NAND
nand write 0x32000000 0 0x30000
http://blog.leshak.ru/2009/02/25/obnovl ... rc6-patch/
My qq2440 page
Sorry, it's russian, but you can use http://translate.google.com/ (ru > en/...)
buserror
Re: 2in1: qq2440 / mini2440 + linux 2.6.29-rc6 ! (upd: 26 Feb)
Post by buserror » Thu Feb 26, 2009 12:24 am
Great stuff ! Glad to see we are 'converging' :-)
LeshaK
Post by LeshaK » Thu Feb 26, 2009 12:31 am
I hope, in the future it will be one branch...
My qq2440 page
buserror
Post by buserror » Thu Feb 26, 2009 12:40 am
Do you have an account on repo.or.cz ? If so, email me and I'll give you write access to all the trees...
What I do in all the tree before I 'push' anything is :
+ I run on my own branch "dev-mini2440-buserror"
When I am ready to push, I make a temporary branch where the last 'stable' was
+ git checkout -b dev-mini2440-staging dev-mini2440-stable
I apply my stuff to that branch:
+ git diff dev-mini2440-buserror | patch -p1
I then selectively make 'clean' commits, using "git-cola". When I have checked back in all the clean patches, I do :
+ git checkout dev-mini2440-stable
Bring my stable beanch forward:
+ git rebase dev-mini2440-staging
Then push !
+ git push repo dev-mini2440-stable dev-mini2440-stable:master
Once that is done, I can force-reset my -buserror branch to where 'stable' is ... and start again hacking :D
LeshaK
Post by LeshaK » Thu Feb 26, 2009 12:46 am
I don't have account on repo.or.cz
and I didn't use git before :( only svn.
I am studying it now...
My qq2440 page
buserror
Post by buserror » Thu Feb 26, 2009 12:51 am
git is a fantastic tool, well worth learning !
Just tell me when you are ready, we'll do it the old-fashioned way until then :-)
LeshaK
Post by LeshaK » Thu Mar 26, 2009 1:53 am
New Linux 2.6.29 kernel patch
http://blog.leshak.ru/2009/03/26/obnovl ... ya-xx2440/
new default:
Both boards: swap - ON
qq2440: lcd - 640x480
mini2440: lcd - 240x320
use:
make
make
My qq2440 page
Sak1s
Re: 2in1: qq2440 / mini2440 + linux 2.6.29 ! (upd: 26 March)
Post by Sak1s » Thu Apr 02, 2009 3:02 am
i compile the kernel 2.6.29 and i apply the rc6 patch and the xx2440-2.6.29-20090326.diff.gz
my system boot from the mmc card but i cant boot from nand with jffs2 ,i got a message "VFS unable to sount"
i use a qq2440V3 board.
Any tips for the jffs2 ?
LeshaK
Post by LeshaK » Thu Apr 02, 2009 3:13 am
Try this howto
http://blog.leshak.ru/english/pages/how ... nd-qq2440/
you can download there my root.jffs2
but use u-boot 1.3.2
make qq2440_config
make
linux 2.6.29 patch
make
My qq2440 page
ndavey
Post by ndavey » Mon Jun 22, 2009 11:20 pm
LeshaK, nice work on the xx2440 boards... I've recently started to play with this board and found your blog articles useful (even the translated Russian ones.. :) )..
Regards
Neil Davey
Users browsing this forum: No registered users and 23 guests
