u-boot 1.3.2 for qq2440 & mini2440 (based on u-boot 1.3.2 mini2440 from Michel Pollet [buserror])
build for qq2440
make qq2440_config
makeCode: Select all
make mini2440_config
makeadd:
- audio support (get from Michel Pollet mini2440 kernel patch)
build for qq2440
make qq2440_defconfig
make mini2440_defconfig
makenew kernel patch will be work only with new u-boot 1.3.2
If you want to run with previous u-boot 1.1.6
open mach-qq2440.c
at the end of file, change:
#ifdef CONFIG_MACH_MINI2440
MACHINE_START(MINI2440, “MINI2440″)
#else
MACHINE_START(QQ2440, “QQ2440V3″)
#endifCode: Select all
MACHINE_START(S3C2440, “MINI2440″)
#else
MACHINE_START(S3C2440, “QQ2440V3″)
#endiffor change old u-boot on new
put new u-boot on tftp and in command line u-boot enter
load new u-boot in ram
tftp 0x32000000 u-boot.binCode: Select all
nand erase 0 0x30000Code: Select all
nand write 0x32000000 0 0x30000
