cannot transfer win ce image through USB!!!
Re: cannot transfer win ce image through USB!!!
I also try mtest from u-boot and get similar memory error:
U-Boot 1.3.2-mini2440 (Oct 6 2009 - 12:51:09)
I2C: ready
DRAM: 64 MB
Flash: 2 MB
NAND: Bad block table not found for chip 0
128 MiB
*** Warning - bad CRC or NAND, using default environment
USB: S3C2410 USB Deviced
In: serial
Out: serial
Err: serial
MAC: 08:08:11:18:12:27
Hit any key to stop autoboot: 0
MINI2440 # mtest
Pattern 00000000 Writing... Reading...
Mem error @ 0x33D5FB2C: found 00000001, expected 00F57ECB
Mem error @ 0x33D5FB30: found 33D5FB2C, expected 00F57ECC
Mem error @ 0x33D5FB34: found 33D5FB2C, expected 00F57ECD
Mem error @ 0x33D5FB38: found 00F57ECD, expected 00F57ECE
Pattern FFFFFFFF Writing...
But i didn't have any problem with transfer the image through USB.
I2C: ready
DRAM: 64 MB
Flash: 2 MB
128 MiB
In: serial
Out: serial
Err: serial
MINI2440 # mtest
I digress here by answering your post nik100, but, Are you using the latest uboot?
The original uboot doesnt like the 128nand, and will give said errors (NAND: Bad block table not found for chip 0)
If you check the main S3C2440 forum (not the wince one) you will find a post or two with the uboot issue and newest version.
Here is the full nand image I just made.
http://www.megaupload.com/?d=3741O3L5
Tried to upload here, but it was too big.
It consists of the NK_N35.bin wince image from 'mini20090817' using the respective nboot.
Hope this helps.
Hope this helps.
I use u-boot attached by mgalemin from here.
Regards!
Regards!
amirshah77
thanks a million nicolas...
my office network blocks megaupload (as well as rapidshare, depositfiles, etc), so i'll have to wait until i get home today to download it. i will tell you tomorrow whether the problem is solved or not...
amirshah77
YAY! it works!!! thanks nicolas...
however, you created an image for the N35 lcd, and i have the T35 one (the screen is shifted a little to the right, leaving a small dark band at the left, might not be able to scroll since the scroll bar will not be visible).
if possible, could you create another backup for T35 lcd as well?
btw, i'm using the same PC, same cables, etc. so i think it must be faulty RAM (leading to checksum failure), although nik100 has pointed out he had similar u-boot mtest errors but can still burn wince...
again, thanks!
again, thanks!
Im cleaning up the work area, so I put it away.
Ill take it out tommorow and do a T35 image.
Here is the T35 version of the nand.
full_nand_20090817_NK_T35.rar
link: http://www.megaupload.com/?d=41ZEFTJW
This is the vivi output during the writting:
Enter your selection: w
Clear the free memory
Please send the Image through USB.
Download Address=0x80200000 Length=0x1c4fca8
...........................Done.
Low Level Format: Start = 0x0500, Num = 0x3fb00
.......................................................................................................Done.
Create Partition: Start = 0x600, Num = 0xe300.
Create Partition: Start = 0xe900, Num = 0x30d00.
...Done.
Start Windows CE...-
amirshah77
thanks nicolas... i really appreciate your help.
i was busy writing some research paper close to the due date and did not visit this forum for quite some time.
latest news: esky-sh/admin sent me a replacement board. now i can burn wince the "correct" way without problem.
previously, i noticed that if i use your NAND image on the old board, even though it can run wince but it became very prone to "hangs". the most annoying thing was that i could not transfer programs i compiled on visual studio, since the transfer would stop halfway (just like when i tried to burn wince the correct way). anyway, the new board does not have these problems...
thanks nicolas and admin.
