Hi I have now waited for 3 hours for the mini2440 utility supervivi
flash info command.
I have miserably failed to find any documentation to the supervivi flash info
one discussion in the web does side the subject, but my chinese is so poor, that I dont understand it.
http://blog.chinaunix.net/u2/78300/showart_1274577.html
at least there is some s3c2440 specific in the code of the blog:
case TYPE_S3C2440:
chip->IO_ADDR_W = regs + S3C2440_NFDATA;
info->sel_reg = regs + S3C2440_NFCONT;
info->sel_bit = S3C2440_NFCONT_nFCE;
chip->cmd_ctrl = s3c2440_nand_hwcontrol;
chip->dev_ready = s3c2440_nand_devready;
break;
but as subject says:
could you tell me how long it takes to get the flash info from supervivi on your board.
how many hours Supervivi flash info takes on your mini2440?
Farawaybay lab run by Eki
Re: how many hours Supervivi flash info takes on your mini2440?
Is there any reason you're not using the H-JTAG application from the DVD and the Parallel JTAG adaptor?
Works fine under Windows (takes about 1 minute) and under Linux using sjf2440 (takes a few minutes).
lack of lpt (parallel printer) port in the PC is the reason not to use it.the_fbi wrote:Is there any reason you're not using the H-JTAG application from the DVD and the Parallel JTAG adaptor?
Thats a bit of a painekilab wrote:lack of lpt (parallel printer) port in the PC is the reason not to use it.the_fbi wrote:Is there any reason you're not using the H-JTAG application from the DVD and the Parallel JTAG adaptor?
Anything in this thread which helps? http://www.friendlyarm.net/forum/topic/40
