mini2440 WindowsCE 6.0 Preliminary(20091130)
Posted: Wed Dec 02, 2009 12:34 am
WindowsCE 6.0 BSP Features:
- Latest SP Release3(2009.10)
- .NET 3.5
- Fully R/W to folders on disk
- WindowsCE 6.0 BSP(and bootloader):
1 - PWM Beeper
2 - CMOS Camera
3 - I2C-EEPROM
4 - ADC
5 - Watchdog
6 - Buttons(6)
7 - LEDs(4)
8 - LCD Backlights
9 - RTC
10 - DM9000
11 - SD Card up to 32G
12 - USB Device Peripherals
13 - Audio playback and record
14 - Touch Screen
15 - LCD(Resulotion:240x320, 800x480, 640x480, 1024x768)
17 - Screen Rotate
18 - 3 COM Drivers(COM0 can be defined for debug)
19 - Nboot header files for customization
20 - StartLogoMaker(XP/Vista, Win7)
WindowsCE 6 Utilities:
- LCD-Test
- PWM-Buzzer
- CMOS Camera
- I2C-EEPROM
- Watchdog
- AD-Convert
- Buttons
- Rotate
- Autorun-Setting
- Recorder
- Serial Assistant
- LED
please check code on ftp server
Posted: Wed Dec 02, 2009 12:40 am
s3c2440/mini20091202/mini2440-20091130pre
Re: mini2440 WindowsCE 6.0 Preliminary(20091130)
Posted: Wed Dec 02, 2009 2:14 am
by Ivanov
it must be christmas...
thank you!
Posted: Mon Dec 07, 2009 12:39 am
by xvx
many thanks
you are a good person
Posted: Thu Dec 31, 2009 10:27 am
by vcelak
Hello guys,
i have tried this preliminary version on my mini2440 128m with A70 lcd, but this works only at time upon download image to board, but after power cycle and configuration with boot from flash this show boot logo and animation, but then it hangs.
i use nboot-a70.bin, custom logo and nk_a70.bin from the wince6-images.rar archive downloaded from your ftp.
Any things or how-to's?
Posted: Sat Jan 02, 2010 2:43 pm
by Delavar
May be you should update supervivi to version provided with this release
Posted: Mon Jan 04, 2010 9:41 pm
by philp
Hi, I'm having the same problem.
CE6 works when I send the image across but upon reset and switching to NAND the splash screen appears but then it freezes.
Delavar, how do I do this? I've tried to upload vivi using the "v" option of DNW but this doesn't work.
I used the supervivi image in mini2440-20091130pre which I downloaded off esky's ftp site.
Do I need to do something different or use JTAG?
Any help would be much appreciated.
Paul
ps->Any sign of CE6 in english?
Posted: Mon Jan 04, 2010 10:46 pm
by nicolas
What version of superviv do you have on the board?
If its 128m board (or newer 64m board) then you probably already have V2.
If not, you will need to use the JTAG to program the new supervivi (unless someone has figured out the proper command line commands to send supervivi to flash itself with the new, bigger, supervivi)
Secondly.
Simply re-build the BSP if you want english.
Posted: Tue Jan 05, 2010 3:56 pm
by philp
Hi Nicholas,
I actually did already have v2 but it didn't work nonetheless.
I used jtag to blast supervivi and replaced it with the version from the mini2440-20091130pre folder but it didn't work at all
Finally I replaced it with a version I found on another folder on the ftp site (version 0945-2k) and that works fine.
Cheers & thanks
Paul
Posted: Sat Jan 16, 2010 4:22 pm
by g_ricketts
Hi Paul,
What folder did you get that version from (the 0945-2k one). I am having the same problems as you were.
Thanks,
George
***************** EDIT ********************
Nevermind, just found it (it's the one in the latest mini20100108/images/wince6.0.rar)
