I'm trying to create a custom kernel for the board and am a little confused about how you implement the NIC driver. I notice that you have the DM9000 driver disabled in the config files found in linux-2.6.28.6-20100904.tar.gz...
Could you please tell me how you get this working without the driver enabled, or failing that, what driver you select for the NIC.
Cheers,
Steven
Custom Kernel
Re: Custom Kernel
I have analysed this a little further and my problems are due the configuration options for the DM9000 IC. I can see that the DM9000.c driver has been rewritten but is, some-what, a mess and so porting it to a newer kernel is not a feasible option. Instead I will try and rewrite this for inclusion into the kernel but will require some details regarding the communications between the DM9000 and the core.
Specifically, I need to know the following:
1) The physical address of the address register
2) The physical address of the data register
3) The IRQ line the device's interrupt pin is connected to. - EINT7 according to the schematic.
I have tried to find this from the kernel source contained within the DVD but the data there is not clear.
I am assuming that the schematics provided on the DVD are correct for this interface? From this and the device data sheet I can see that the device has been set up as a 8-bit device but still has a 16-bit bus going to it... Is this an error somewhere or is this the correct set-up?
Cheers,
Steven
Cheers,
Steven
Re: Custom Kernel
S3C6410 memory mapping is fixed, you can find it according specific Chip selection signal.
