AM335X U-Boot boards.cfg file
TI Sitara Cortex-A8 MPU and it's companion boards
Post by esky-sh » Fri Jul 12, 2013 9:16 pm
# List of boards
# Syntax:
# white-space separated list of entries;
# each entry has the fields documented below.
# Unused fields can be specified as "-", or omitted if they
# are the last field on the line.
# Lines starting with '#' are comments.
# Blank lines are ignored.
# The CPU field takes the form:
# cpu[:spl_cpu]
# If spl_cpu is specified the make variable CPU will be set to this
# during the SPL build.
# The options field takes the form:
# <board config name>[:comma separated config options]
# Each config option has the form (value defaults to "1"):
# option[=value]
# So if you have:
# FOO:HAS_BAR,BAZ=64
# The file include/configs/FOO.h will be used, and these defines created:
# #define CONFIG_HAS_BAR 1
# #define CONFIG_BAZ 64
# The list should be ordered according to the following fields,
# from most to least significant:
# ARCH, CPU, SoC, Vendor, Target
# To keep the list sorted, use something like
# :.,$! sort -bdf -k2,2 -k3,3 -k6,6 -k5,5 -k1,1
# To reformat the list, use something like
# :.,$! column -t
# Target ARCH CPU Board name Vendor SoC Options
am335x_evm arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1
am335x_evm_nor arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,NOR
am335x_evm_norboot arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,NOR,NOR_BOOT
am335x_evm_spiboot arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,SPI_BOOT
am335x_evm_uart1 arm armv7 am335x ti am33xx am335x_evm:SERIAL2,CONS_INDEX=2
am335x_evm_uart2 arm armv7 am335x ti am33xx am335x_evm:SERIAL3,CONS_INDEX=3
am335x_evm_uart3 arm armv7 am335x ti am33xx am335x_evm:SERIAL4,CONS_INDEX=4
am335x_evm_uart4 arm armv7 am335x ti am33xx am335x_evm:SERIAL5,CONS_INDEX=5
am335x_evm_uart5 arm armv7 am335x ti am33xx am335x_evm:SERIAL6,CONS_INDEX=6
am335x_evm_usbspl arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,SPL_USBETH_SUPPORT
am335x_evm_restore_flash arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,RESTORE_FLASH
am335x_evm_restore_flash_usbspl arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,RESTORE_FLASH,SPL_USBETH_SUPPORT
am335x_evm_uart_usbspl arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,UART_THEN_USB_SPL,SPL_USBETH_SUPPORT
am335x_evm_restore_flash_uart_usbspl arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,RESTORE_FLASH,UART_THEN_USB_SPL,SPL_USBETH_SUPPORT
