need kernel headers directory to build loadable modules
tarek.elsherbiny
Re: need kernel headers directory to build loadable modules
Post by tarek.elsherbiny » Sun Mar 08, 2009 8:41 am
I have only installed the latest cross development arm-linux-gcc-3.4.1.tgz
and here is the o/p:
arm-linux-gcc -v
Reading specs from /usr/local/arm/3.4.1/bin/../lib/gcc/arm-linux/3.4.1/specs
Configured with: /opt/crosstool/crosstool-0.28/build/arm-linux/gcc-3.4.1-glibc-2.3.2/gcc-3.4.1/configure --target=arm-linux --host=i686-host_pc-linux-gnu --prefix=/opt/crosstool/arm-linux/gcc-3.4.1-glibc-2.3.2 --with-float=soft --with-headers=/opt/crosstool/arm-linux/gcc-3.4.1-glibc-2.3.2/arm-linux/include --with-local-prefix=/opt/crosstool/arm-linux/gcc-3.4.1-glibc-2.3.2/arm-linux --disable-nls --enable-threads=posix --enable-symvers=gnu --enable-__cxa_atexit --enable-languages=c,c++ --enable-shared --enable-c99 --enable-long-long
Thread model: posix
gcc version 3.4.1
I am compiling and running applications on the board perfectly. I only have a problem with building kernel modules
Post by esky-sh » Sun Mar 08, 2009 4:30 pm
what is your linux host is?
tarek.elsherbiny
Post by tarek.elsherbiny » Mon Mar 09, 2009 1:44 am
Linux host is Dell Inspiron E1505 runnig Ubuntu 8.10
I found a similar problem in differnet forum talking about another platform but the solution was updating the kernel.
Anyway I am only trying to compile a basic loadable module so if anyone ever succeeded in doing this please pass me any example.
Post by esky-sh » Mon Mar 09, 2009 3:36 am
I have my ubuntu 8.10 running on my laptop either. I have arm-gcc installed on ubuntu according procedures and I can successfully build the kernel. Could you try to load another package from our ftp server and try another installation and build?
tarek.elsherbiny
Post by tarek.elsherbiny » Tue Mar 10, 2009 12:57 am
Thank you so much I have downloaded the linux-2.6.13-mini2440-xxxx.tgz wich was not porvided on the CD.
Extracting the file to /opt/FriendlyARM/mini2440 solved the problem.
Now I can compile kernel module
:D
Post by esky-sh » Tue Mar 10, 2009 1:25 am
:lol:
