igo 8 running on qq2440
Here is picture of igo 8 running on qq2440 and bluetooth GPS connected to it
http://crazy-embedder.blogspot.com/2009 ... works.html
Re: igo 8 running on qq2440
This is really cool! I had never seen a GPS can run under 800x480 resolution before. Could you give us more info for igo 8?
Igo 8 is on SD card. You need to change SYS.TXT
[interface]
resolution_dir="800_480"
vga=0
[rawdisplay]
highres=0
screen_x=800
screen_y=480
I need to test it in real car.
[interface]
vga=0
[rawdisplay]
highres=0
screen_x=800
screen_y=480
How about the BT dongle support? Is it included in the image or you have built new CE image with additional components?
USB BT support is included in platform. You need to leave only USB driver and delete other BT drivers. I will post the details later, when I finish.
I have posted the howto 1st part
http://crazy-embedder.blogspot.com/2009 ... howto.html
What kind of a BT dongle is yours?
I tried with a generic one with I.S.S.C 1002 chipset but when it is plugged, the OS asks for a driver name? Is there a need to place the VID and PID of the dongle somewhere in the registry?
Now it works with I.S.S.C dongle. Bluetooth discovery works.
Now I have to build a tool to perform this setup of virtual com port over bluetooth. There is a nice example in the msdn called "BTSquirt" http://msdn.microsoft.com/en-us/library/cc500412.aspx.
Is it possible to perform this setup with registry settings only?
I have used the printUI example from Windows CE samples. I'm still working on it. I'm changing it to something useful for GPS. I don't know if you can do it only from registry.
