USB port not working,any other options than DNW
HEllo,
My USB port with SBC HW is not working.
DNW not able to identify USB even though i have installed correct Driver(Using XP).
I would like to check the supplied linux images using SBC HW board.
Can anybody suggest any other way to transfer or download the images.
HW serial Rs232 port is working correctly.
thanks ,
Nirav
thanks ,
Nirav
Re: USB port not working,any other options than DNW
What is listed in Device Manager for the board ? (in the usb section)
Device/board is not identified at all.
Is there any another way to see the images working.
regards, thanks,
Nirav
regards, thanks,
Nirav
Ah well if windows doesnt even see the board then the software aspect is your least worries.
Are you sure nothing shows up, either with a question mark or with the name "FriendlyArm" ?
Yes,
nothing shows up, Neither with a question mark nor with the name "FriendlyArm" ?
i do not know how can i download the image then.
I would check the USB ports on your computer.
Check the USB cable. Try different ports.
First did you install the new supervivi on it ??
install the old supervivi back in the NOR.
you can find it on the ftp server.
I checked with old supervivi, but USB is not working.
I am using Windows Essential, Is this a problem because of OS?
Do u know how can i check that correct windows USB driver has been installed without connecting the HW board.
thanks
Nriav
thanks
Nriav
