QQ2440 image problem
Re: QQ2440 image problem
nothing changed
still the program freeze from sending.
New supervivi works perfect for qq2440. Thank you very much! Now I can use new images.
IDrenth: check that you use the right dnw version - I took it from qq2440 cd
I use the DNW50A
Wich one do you use for the QQ2440 ??
In the attach is the one I use.
Linux works with this one, but the wince version from the mini doesn't work on my QQ2440
- 0.50Adnw.rar
- DNW50A
- (21.07 KiB) Downloaded 584 times
Take it from ftp. qqcd1/windows tools/dnw
still the same problem. If I send the .bin file it freeze.
delvar do you have the wince mini version running on youre bord ??
I didn't understand your question.
Last mini2440 WinCE images works on qq2440 with new supervivi. And they run faster. You need to flash new supervivi with JTAG. After this any DNW should work (use option w). It freezes for 3-4 sec after downloading, but after this it works.
I will test it again.
I will wait this time longer with transfering.
I have the new supervivi on my qq2440.
But every image from mini if I send it it freeze.
But I will try it again.
do you send first the nboot and then the .bin image ?
It doesn't matter what you send first. Nboot and WinCE image have different areas in flash. For testing you can send only WinCE image and start it with supervivi (option -b)
So I try it again and this time I made a movie from it.
Linux is no problem to send it but only the wince image.
So maybe you will find the problem in the movie.
http://www.youtube.com/watch?v=UzcHtUYG4sE
Users browsing this forum: No registered users and 39 guests
