USB port not working,any other options than DNW
nirav700
Post by nirav700 » Wed Nov 11, 2009 3:26 am
HEllo,
My USB port with SBC HW is not working.
DNW not able to identify USB even though i have installed correct Driver(Using XP).
I would like to check the supplied linux images using SBC HW board.
Can anybody suggest any other way to transfer or download the images.
HW serial Rs232 port is working correctly.
thanks ,
Nirav
Re: USB port not working,any other options than DNW
Post by nicolas » Sat Nov 14, 2009 11:47 pm
What is listed in Device Manager for the board ? (in the usb section)
nirav700
Post by nirav700 » Wed Nov 18, 2009 5:08 am
Device/board is not identified at all.
Is there any another way to see the images working.
regards, thanks,
Nirav
Post by nicolas » Wed Nov 18, 2009 9:29 am
Ah well if windows doesnt even see the board then the software aspect is your least worries.
Are you sure nothing shows up, either with a question mark or with the name "FriendlyArm" ?
nirav700
Post by nirav700 » Fri Nov 20, 2009 1:39 am
Yes,
nothing shows up, Neither with a question mark nor with the name "FriendlyArm" ?
i do not know how can i download the image then.
Post by nicolas » Fri Nov 20, 2009 1:49 am
I would check the USB ports on your computer.
Check the USB cable. Try different ports.
IDrenth
Post by IDrenth » Wed Nov 25, 2009 8:05 pm
First did you install the new supervivi on it ??
install the old supervivi back in the NOR.
you can find it on the ftp server.
nirav700
Post by nirav700 » Wed Dec 02, 2009 2:38 am
I checked with old supervivi, but USB is not working.
I am using Windows Essential, Is this a problem because of OS?
Do u know how can i check that correct windows USB driver has been installed without connecting the HW board.
thanks
Nriav
