Qt-Embedded 4.5
bullt
Qt-Embedded 4.5
Post by bullt » Fri Nov 20, 2009 10:25 am
I make my Mini2440 programs with Qt Embedded, but I have problems with the installation:
PC Operating System: Debian-Linux.
Program installed on PC: Qt SDK.
I want to install Qt-Embedded-Linux-4.5, but when you run ". / Configure-embedded arm-xplatform qws / linux-arm-g + +-prefix / usr / local / qt-qt-mouse-tslib-little-endian" I get the following weaknesses:
The tslib functionality test failed!
You might need to modify the include and library search paths by editing
QMAKE_INCDIR and QMAKE_LIBDIR in
/ home/bullt/qt-embedded-linux-opensource-src-4.5.3/mkspecs/qws/linux-arm-g + +.
Nor let me run the make:
make: *** No target specified and no found no makefile. High.
The file qmake.conf
# Qmake configuration for building with arm-linux-g + +
include (../../ common / g + +. conf)
include (../../ common / linux.conf)
include (../../ common / qws.conf)
# Modifications to g + +. Conf
QMAKE_CC = arm-linux-gcc
QMAKE_CXX = arm-linux-g + +
QMAKE_LINK = arm-linux-g + +
QMAKE_LINK_SHLIB = arm-linux-g + +
# Modifications to linux.conf
QMAKE_AR = arm-linux-ar CQS
QMAKE_OBJCOPY = arm-linux-objcopy
QMAKE_STRIP = arm-linux-strip
load (qt_config)
Thanks for the help
Steve
Re: Qt-Embedded 4.5
Post by Steve » Sun Nov 22, 2009 5:01 pm
I got Qt Embedded working following the instructions on this site. From the error message it looks like you might not have installed tslib.
Users browsing this forum: No registered users and 6 guests
