USB-WiFi Driver
Fat_Tony
USB-WiFi Driver
Post by Fat_Tony » Sun Jan 10, 2010 6:09 am
I use the mini2440 with Win CE 6.0.
Last Weak I board a USB-WiFi-Stick:
http://blu-max.com/products/wlan_adapter.html
I choose this one because a Win Ce Driver is available.
So I download the driver from the Homepage an follow the manual to install it.
But when I put the stick in, a window appears in my Display with the following message:
That means :
Unknown USB device
Enter the name of the USB device:
driver name:
I try it with "RT2870" an some other names but with no result.
Can someone help me with this problem?
Re: USB-WiFi Driver
Post by nicolas » Sun Jan 10, 2010 1:26 pm
You need to COPY the driver dll file to the windows directory.
Then enter the name of the driver dll without the .dll.
(example. wifi.dll you enter wifi)
Fat_Tony
Re: USB-WiFi Driver
Post by Fat_Tony » Sun Jan 10, 2010 2:14 pm
That don't work.
I tried it with the driver for WinCE 5.0, and it works.
But no popup window appears with the setup for the wifi.
I think the dll for WinCE 6.0 is not working correctly!
The mini2440 is a ARMV4I Board right ?
Elamytoonlymn
USB WiFi Driver
Post by Elamytoonlymn » Sun Feb 14, 2010 6:21 am
I have problems with my network adaptors: 1 Marvell Yukon 88E8039 and 2 Intel 3945abg. None are working. I am thinking of buying a wifi usb dongle either Linksys or D-link. How do i get the driver to install this in Kalyway Tiger 10.4.10?
jldzcxlxn
Re: USB-WiFi Driver
Post by jldzcxlxn » Fri Mar 26, 2010 12:16 pm
Hey Tony can you connect to the internet using this USB?? Can you connect to a Wireless Network with password??
InsilsliceFef
USB WiFi Driver
Post by InsilsliceFef » Tue Jun 15, 2010 4:42 pm
A lot of USB wifi dongles get modified by soldering a wire to the antenna for better reception. Couldnt this be done to the musicpal ?
InsilsliceFef
USB WiFi Driver
Post by InsilsliceFef » Sun Aug 01, 2010 3:30 am
Hi to all. I have got a zaurus c3200 with sharp rom and a usb doongle wifi sitecom with chipset rtl8187. unfortunately my zaurus dont recognize it. are the a solution? How I can to install the driver? thanks so much
