Do you have sample version for keil ?
mini2440test.bin can be run on power on but my project cant, something must be wrong with settings.
thanks
keil sample of mini2440test
Re: keil sample of mini2440test
I have been developping with Keil everything seems good builded like object object oriented structure but my problem is running my program on power on. I have rearranged 2440init.s and using RuninFlash.sct and upload my program (a) absolute program option but still nothing on power.
program works well on Ram (d) option.
have not found any document about that problem.
thanks all somehow I didkemalony76 wrote:I have been developping with Keil everything seems good builded like object object oriented structure but my problem is running my program on power on. I have rearranged 2440init.s and using RuninFlash.sct and upload my program (a) absolute program option but still nothing on power.
Do you think you could lead us through a step by step procedure using Keil please, it would be very useful. Did you use the included "Parallel port wiggler JTAG emulator(for H-JTAG) " for talking to the board, and did you have to alter the Keil start up code or do anything special in your code?.
P.
P.
