Still need to flash something on the fake flash and try it more in depth. It's really cool to be able to simulate the whole board like that
[michel@yap /opt/qemu/qemu-trunk.git]% . ./mini2440_start.sh
s3c_gpio_write: Bad register 0xd0
U-Boot 1.3.2-moko12 (Feb 3 2009 - 18:53:41)
I2C: ready
DRAM: 64 MB
Flash: 2 MB
NAND: 64 MiB
Found Environment offset in OOB..
USB: S3C2410 USB Deviced
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 0
MINI2440 # s3c24xx speed get
FCLK = 405 MHz, HCLK = 101 MHz, PCLK = 50 MHz, UCLK = 48 MHz
MINI2440 # printenv
bootcmd=
bootdelay=3
baudrate=115200
ethaddr=08:08:11:18:12:27
ipaddr=10.0.0.111
serverip=10.0.0.4
netmask=255.255.255.0
usbtty=cdc_acm
bootargs_base=rootfstype=jffs2 root=/dev/mtdblock4 console=ttySAC0,115200
mtdids=nand0=mini2440-nand
mtdparts=mtdparts=mini2440-nand:256k@0(u-boot),128k(env),5m(kernel),-(root)
mini2440=4tb
bootargs=root=/dev/mtdblock4 rootfstype=jffs2 console=ttySAC0,115200 mini2440=4tb
partition=nand0,0
mtddevnum=0
mtddevname=u-boot
Environment size: 456/65532 bytes
MINI2440 # bootm
## Booting kernel from Legacy Image at 32000000 ...
Image Name:
Created: 2009-02-23 8:28:41 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2474204 Bytes = 2.4 MB
Load Address: 30008000
Entry Point: 30008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux............................................................................................................................................................. done, booting the kernel.
s3c_timers_write: Bad register 0x40
Initializing cgroup subsys cpu
Linux version 2.6.29-rc6-michel (michel@yap) (gcc version 4.2.4) #193 PREEMPT Mon Feb 23 08:28:38 GMT 2009
CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177
CPU: VIVT data cache, VIVT instruction cache
Machine: MINI2440
Memory policy: ECC disabled, Data cache writeback
CPU S3C2440A (id 0x32440001)
S3C24XX Clocks, (c) 2004 Simtec Electronics
S3C244X: core 405.000 MHz, memory 101.250 MHz, peripheral 50.625 MHz
CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: root=/dev/mtdblock4 rootfstype=jffs2 console=ttySAC0,115200 mini2440=4tb
irq: clearing subpending status 00000002
PID hash table entries: 256 (order: 8, 1024 bytes)
Console: colour dummy device 80x30
console [ttySAC0] enabled
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
allocated 327680 bytes of page_cgroup
please try cgroup_disable=memory option if you don't want
Memory: 64MB = 64MB total
Memory: 59220KB available (4592K code, 574K data, 160K init)
SLUB: Genslabs=12, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Calibrating delay loop... 395.67 BogoMIPS (lpj=989184)
Mount-cache hash table entries: 512
Initializing cgroup subsys ns
Initializing cgroup subsys cpuacct
Initializing cgroup subsys memory
CPU: Testing write buffer coherency: ok
net_namespace: 672 bytes
NET: Registered protocol family 16
MINI2440: Option string mini2440=4tb
MINI2440: LCD 0:240x320 1:800x480 2:1024x768 3:800x600 [4:640x480]
s3c24xx-pwm s3c24xx-pwm.1: tin at 25312500, tdiv at 25312500, tin=divclk, base 8
S3C2440: Initialising architecture
S3C2440: IRQ Support
S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics
DMA channel 0 at c4808000, irq 33
DMA channel 1 at c4808040, irq 34
DMA channel 2 at c4808080, irq 35
DMA channel 3 at c48080c0, irq 36
S3C244X: Clock Support, DVS off
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Bluetooth: Core ver 2.14
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
NetWinder Floating Point Emulator V0.97 (extended precision)
audit: initializing netlink socket (disabled)
type=2000 audit(0.315:1): initialized
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 115
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
Console: switching to colour frame buffer device 160x80
fb0: s3c2410fb frame buffer device
s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440
s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440
brd: module loaded
loop: module loaded
nbd: registered device at major 43
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
dm9000 Ethernet Driver, V1.31
eth0 (dm9000): not using net_device_ops yet
eth0: dm9000e at c486a300,c486e304 IRQ 51 MAC: 52:54:00:12:34:56 (chip)
Driver 'sd' needs updating - please use bus_type methods
S3C24XX NAND Driver, (c) 2004 Simtec Electronics
s3c2440-nand s3c2440-nand: Tacls=1, 9ns Twrph0=3 29ns, Twrph1=2 19ns
NAND device: Manufacturer ID: 0xec, Chip ID: 0x36 (Samsung NAND 64MiB 1,8V 8-bit)
Scanning device for bad blocks
Creating 4 MTD partitions on "NAND 64MiB 1,8V 8-bit":
0x000000000000-0x000000040000 : "u-boot"
uncorrectable error : <3>uncorrectable error : <5>0x000000040000-0x000000060000 : "u-boot-env"
uncorrectable error : <5>0x000000060000-0x000000560000 : "kernel"
uncorrectable error : <3>uncorrectable error : <5>0x000000560000-0x000004000000 : "root"
uncorrectable error : <3>uncorrectable error : <6>ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
s3c2410-ohci s3c2410-ohci: S3C24XX OHCI
s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1
s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000
s3c2410-ohci s3c2410-ohci: init err (00000000 0000)
ohci_hcd: can't start s3c24xx
s3c2410-ohci s3c2410-ohci: startup error -75
s3c2410-ohci s3c2410-ohci: USB bus 1 deregistered
s3c2410-ohci: probe of s3c2410-ohci failed with error -75
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver libusual
mice: PS/2 mouse device common for all mice
s3c2440-ts s3c2440-ts: Starting
s3c_adc_write: Bad register 0x8
Created group ts filter len 12 depth 2 close 10 thresh 6
Created Median ts filter len 20 depth 2 dec 24
Created Mean ts filter len 4 depth 2 thresh 65535
Created Linear ts filter depth 2
s3c2440-ts s3c2440-ts: 4 filter(s) initialized
s3c2440-ts s3c2440-ts: successfully loaded
input: s3c2410 TouchScreen as /devices/virtual/input/input0
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling
s3c2410-rtc s3c2410-rtc: rtc core: registered s3c as rtc0
i2c /dev entries driver
s3c2440-i2c s3c2440-i2c: slave address 0x10
s3c2440-i2c s3c2440-i2c: bus frequency set to 98 KHz
s3c_i2c_write: Bad register 0x10
s3c2440-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled
Bluetooth: Generic Bluetooth USB driver ver 0.4
usbcore: registered new interface driver btusb
Bluetooth: Generic Bluetooth SDIO driver ver 0.1
cpuidle: using governor ladder
mapped channel 0 to 0
s3c2440-sdi s3c2440-sdi: powered down.
s3c2440-sdi s3c2440-sdi: initialisation done.
s3c2440-sdi s3c2440-sdi: running at 0kHz (requested: 0kHz).
s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz).
s3c_mmci_readw: FIFO underrun
Registered led device: led1
Registered led device: led2
Registered led device: led3
Registered led device: led4
usbcore: registered new interface driver hiddev
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
Advanced Linux Sound Architecture Driver Version 1.0.18a.
No device for DAI UDA134X
No device for DAI s3c24xx-i2s
S3C24XX_UDA134X SoC Audio driver
UDA134X SoC Audio Codec
asoc: UDA134X <-> s3c24xx-i2s mapping ok
ALSA device list:
#0: S3C24XX_UDA134X (UDA134X)
TCP cubic registered
Initializing XFRM netlink socket
NET: Registered protocol family 17
NET: Registered protocol family 15
Bridge firewalling registered
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
registered taskstats version 1
s3c2410-rtc s3c2410-rtc: setting system clock to 2009-02-23 23:21:21 UTC (1235431281)
Root-NFS: No NFS server available, giving up.
VFS: Unable to mount root fs via NFS, trying floppy.
List of all partitions:
1f00 256 mtdblock0 (driver?)
1f01 128 mtdblock1 (driver?)
1f02 5120 mtdblock2 (driver?)
1f03 60032 mtdblock3 (driver?)
No filesystem could mount root, tried: jffs2
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
