Firmware Release
Firmware Release
Post by esky-sh » Fri Aug 11, 2023 3:39 am
2026-4-14 update
v7.19 -- Model 3/4/5/5P/6/6P/7
Change logs
  • USB read/write speed ​​improve to internal storage space
  • Enhanced animation effects for FlipClock
2026-3-27 update
v8.38 -- Model 2/2W/5C/5S/8
Change logs
2026-2-9 update
v8.34 -- Model 5S/8
Change logs
  • An experimental media player in Elephant
  • Photos/Album appearance improve in Elephant
  • Backlight setting in Elephant
  • Enhanced animation effects in Elephant
  • Display correct hardware info in Elephant
2026-1-10 update
v8.32 -- Model 5S/8
Change logs
  • Fix Elephant desktop UI in a reasonable resolution
2025-12-20 update
v8.30 -- Model 5S/8
Change logs
  • Performance improve in video playback
2025-10-5 update
v8.28 -- Model 2/2W
Change logs
  • Fix a bug in write through mode
v7.18 -- Model 3/4/5/5P/6/6P/7
Change logs
  • Support s/n retrieve in Status-Link info
2025-6-3 update
v8.24 -- Model 5S
Change logs
  • Support switching between Album and Elephant mode
  • Screen rotation setting in BeadaTools
2025-3-6 update
v8.20 -- Model 2/2W/5C
Change logs
  • Fix gif issue in album mode
  • Fix R/B color swap issue in 2/2W model
2024-3-26 update
v8.12 -- Model 2/2W/5C
Change logs
  • flip element added in Panel-Link
2024-3-14 update
v7.15 -- Model 3/4/5/5P/6/6P/7
Change logs
  • Fix continuous picture feeding issue
  • Fix multiple sessions freezing issue
  • Fix flipclock blank screen issue
  • Expand raw video format to a wider range
    { BGRA, RGBA, BGRx, RGBx, BGR, NV16, UYVY, YVYU, YUY2, I420, YV12, Y42B, NV21, NV12, RGB16, BGR16}
2024-1-30 update
v7.13 -- Model 3/4/5/5P/6/6P/7
Change logs
  • Provide 8-8-8 bit width support in LCD frame buffer driver
2023-8-11 update
v7.12 -- Model 3/4/5/5P/6/6P/7
v8.05 -- Model 5C
Change logs
  • Continuous jpeg/png stream support in single Panel-Link session
Users browsing this forum: No registered users and 211 guests
