Partition Issue
Re: Partition Issue
It appears that Normal Boot mode no longer functions - this is with no jumpers, correct? The device does not show up anywhere (RNDIS or Network / Device Manager etc) unless it is in USB Memory Stick mode.
Also for troubleshooting the blue light is flashing on the device.
Re: Partition Issue
EXT4 partition got erased so there is no firmwares on your device now. You will have to re-load all firmware stuff.
Re: Partition Issue
You can follow this link for reload firmware.
https://1drv.ms/f/s!ArGfiTxjUGUl_i3_cPn ... 8?e=2afp0w
Re: Partition Issue
Because there were no EXT4 partitions on the drive I created one as DG requires a partition to place the image file - I use this one, correct?
This leaves me with one partition on the drive:
- 5.png (147.38 KiB) Viewed 193 times
- 4.png (20.52 KiB) Viewed 193 times
Re: Partition Issue
Since partition table on BeadaPanel already been cleared. So first step you should recover this table.
Please pickup the ptf file and let DiskGenius recover partition table on BeadaPanel. Please do not let windows do anything to BeadaPanel! Just operate in DiskGenius. If you are not sure what should be next steps, just ask at this forum first. Or DiskGenius may damage your PC if wrong instructions been sent.Re: Partition Issue
Ok - recovered the partition table and then restored the image to the EXT4 partition.
- 6.png (148.32 KiB) Viewed 191 times
Re: Partition Issue
After restore EXT4 partition, you still need format FAT32 partition and copy several files to FAT16 partition.
Re: Partition Issue
Doing that now - do I need to change the volume names or anything else other than copy the fat16 files over and then format the fat32 partition... or change drive letters?
Thank you.
Thank you.
Re: Partition Issue
nothing else. just eject this LinuxFile-StorGadget from DiskGenius and then power cycle the BeadaPanel.
Users browsing this forum: No registered users and 13 guests
