dezso
Post by dezso » Mon Jan 30, 2012 9:46 pm
nk.bin has 0 byte file size !
Is the upload in progress or its a corrupted file ?
Post by esky-sh » Mon Jan 30, 2012 11:00 pm
dezso wrote:nk.bin has 0 byte file size !
We were facing an internet connection issue to our FTP server since from yesterday. We will update you after issue removed.
Post by esky-sh » Tue Jan 31, 2012 12:03 am
We setup a temporary server:
.png
.png (3.88 KiB) Viewed 17989 times
You may download same image from the ftp above.
dezso
Post by dezso » Tue Jan 31, 2012 5:46 am
That is a success, USB, Ethernet, Touch, VR, Back-lite control.... all works fine.
Butt his image also based on Ram-Rom fs, non of setting retained after reboot, I believe Rom only fs would be much more useful.
Ty
Post by esky-sh » Tue Jan 31, 2012 5:25 pm
dezso wrote:That is a success, USB, Ethernet, Touch, VR, Back-lite control.... all works fine.
Ty
Thanks for verifying it on BB xM Rev. C. We may include this system hive resident feature in next release.
dezso
Post by dezso » Tue Jan 31, 2012 10:30 pm
Shouldn't be that hard.
CoreOS--File Systems and Data Store--File System Internal--select ROM-only
CoreOS--File Systems and Data Store--Registry Storage-- select Hive-based Registry
Sysgen ?!?
Post by esky-sh » Wed Feb 01, 2012 12:10 am
Shouldn't be so easy?
As far as I knew, Windows sytem hive should be divided into 2 parts -- .bin resident and FAT resident, if you want a FAT/SD resident registry.
.bin resident hives help wince to boot up, and FAT/SD resident hives can be runtime alternated.
I am not sure if this kind of jobs get done automatically when I simply click through the settings inside PB 7.0 as you mentioned above?
Someone pullme out? :(
dezso
Post by dezso » Wed Feb 01, 2012 5:31 pm
I have build Ti's demo BSP with HIVE and ROM-ONLY just fine, couldn't get LCD and VR running tho..
Post by esky-sh » Wed Feb 01, 2012 6:03 pm
this is our current settings for evaluation image:
dezso
Post by dezso » Wed Feb 01, 2012 9:29 pm
The image you provided last was build with this setting ?!
Look like we have been using ram-disk, "HKEY_LOCAL_MACHINE\System\StorageManager\AutoLoad\RAMDisk"
There is might be similar setting for CE7 as CE6, like
[HKEY_LOCAL_MACHINE\init\BootVars]
"Start DevMgr"=dword:1
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\]
"Profile"="FlashDisk"------ this most likely needed to be SD card?!
"Flags"=dword:1000
[HKEY_LOCAL_MACHINE\System\StorageManager\Profiles\FlashDisk\FATFS]
"MountAsRoot"=dword:1
"MountAsBootable"=dword:1
"MountPermanent"=dword:1
My BSP was installed in one of the Virtual Server, that is offline at this time, can't install it on my desktop since CE6 exist.
I'll try to get XP up and running in a Virtual-box than will see how smooth the CE7 install goes. "Last time was disaster"
