Now I think its safe to say I was patient all this time waiting for update.
Why no one "who knows how" have fixed the back-lite control for wince6 R3, my board cant control the back-lite at all, no mater what is the time set to the back-lite will never tun off.
Any one have solution for this !
Backlite control
Re: Backlite control
The PWM/Backlight control is similar between wince and linux. You can port the PWM driver in linux kernel to wince yourself, if you can not wait so long a time frame.
I'm sorry but I don't speak linux or unix or even C, my skill stops at C#.
I need some one to help me out here, I don't need PWM brightness control, simply I don't want my backlite to run 24x7.
Currently OS CE6 can't turn back-lite off....
i asked for some help back in may
dezso wrote:Hello
I really need you guys to fix the WinCE6 BSP.
The backlite constantly ON !!
Will not turn off no mater what is the settings set to.
Is it registry ? IO port setting? OS build? what ever is it please look in to it and fix it.
dezso:
I cant believe every one who purchased one of this board from you guys are expert or using Qt.
WinCE 6 will not turn back light off at all, I don't want to end up like this user
Please point me to some direction !!!
Don't regret me for buying board from you since friendly arm board different and their BSP wont work with this board.
http://www.friendlyarm.net/products/mini6410?lang=en
I think I waited for a long time now.esky-sh wrote:The PWM/Backlight control is similar between wince and linux. You can port the PWM driver in linux kernel to wince yourself, if you can not wait so long a time frame.
